Output to 2 sound cards Simultaneously
2010-02-08T01:06:27+00:00
I have many reasons why I would want to output to multiple sound cards simultaneously. I know I am not the only one who was this problem based on a couple quick bing searches.
I would like to be able to output sound to multiple sound cards at the same time instead of having to switch the "default device" in the audio panel all the time I want them ALL to be the default device. I want to use my USB headset and my speakers at the same time. I know windows is capable of this because while one is playing I can "test" the other and they both play sound at the same time
As far as I know there is simply no setting for this. PLEASE HELP!
2010-02-08T20:07:19+00:00
Unfortunately this cannot be accomplished, as it is by-design,
Here only one device can be marked as default device, for more information follow these below steps.
  1. Click Start, type Sound in the Start Search box.
  2. Click Sound in the search results at the top of the Start menu.
  3. Click the Playback tab. Notice the check mark next to the default device.
As this is a by-design issue, there would be nothing much we can do from our end.
If you want to suggest change in the design here is the link you can refer to:  Microsoft Connect - Product Feedback and Bug Reporting | Microsoft...
https://connect.microsoft.com/dashboard/info/
Thanks and Regards:
I. Suuresh Kumar- Microsoft Support.
42 additional answers
    2012-12-25T13:11:42+00:00
    write this in a BAT file it starts VAC selects your desired sound devices . VAC is automatically mininmised to sys tray :)
    start /min "audiorepeater" "C:\Program Files\Virtual Audio Cable\audiorepeater.exe" /Input:"Line 1 (Virtual Audio Cable)"  /Output:"Speakers (USB Multi-Channel Aud" /SamplingRate:44100 /AutoStart
    start /min "audiorepeater" "C:\Program Files\Virtual Audio Cable\audiorepeater.exe" /Input:"Line 1 (Virtual Audio Cable)"  /Output:"Lounge (Realtek High Definition" /SamplingRate:44100 /AutoStart
    you have to change output to match your devices only 31 Charcters
    2013-01-16T22:33:46+00:00
    I found better solution.
    go to:
    -playback devices (sound)
    -Recording
    right click and (show disabled devices)
    then enable "Stereo Mix"
    and set Stereo Mix as default
    right click to stereo mix
    properties and "Listen"
    mark "Listen to the device"
    and set "HDMI Output..."
    hit OK
    and VOILA
    It worked for me
    2013-01-23T04:52:15+00:00
    I signed in just to tell you how helpful this was.  Thanks A+++ if you had a paypal button I'd buy you a beer mate!  Cheers!
    2013-01-26T18:55:27+00:00
    go to:
    -Recording
    hit OK
    and VOILA
    you sir are a genius. there is no need of any VAC or macros. here is how i made it work under win8 pro with your help:
    It worked for me with the following cards and setups:
    1. Realtek Audio card (built in Asus motherboard - make sure this is enabled in bios)
    2. Creative SB Audigy pci
    A. under Playback devices i selected one card (realtek speakers and NOT digital) as default audio device
    B. under Recording tab i selected 'stereo mix' as default and under properties then under Listen tab l selected "listen to this device" and under Playback through this device select another card however make sure is Analog and not digital (spdif or optical). in my case i had Speakers (creative sb audigy)
    C. make sure you have no audio running while you setup or at least close and reopen the audio application after the changes.
    I have also made it work with digital spdif for my creative card with enabeling the 'digital output only' under the speaker properties.
    It may not work for all of you but you can give it a try
    good luck
