Output to 2 sound cards Simultaneously
2010-02-08T01:06:27+00:00
I have many reasons why I would want to output to multiple sound cards simultaneously. I know I am not the only one who was this problem based on a couple quick bing searches.
I would like to be able to output sound to multiple sound cards at the same time instead of having to switch the "default device" in the audio panel all the time I want them ALL to be the default device. I want to use my USB headset and my speakers at the same time. I know windows is capable of this because while one is playing I can "test" the other and they both play sound at the same time
As far as I know there is simply no setting for this. PLEASE HELP!
2010-02-08T20:07:19+00:00
Unfortunately this cannot be accomplished, as it is by-design,
Here only one device can be marked as default device, for more information follow these below steps.
  1. Click Start, type Sound in the Start Search box.
  2. Click Sound in the search results at the top of the Start menu.
  3. Click the Playback tab. Notice the check mark next to the default device.
As this is a by-design issue, there would be nothing much we can do from our end.
If you want to suggest change in the design here is the link you can refer to:  Microsoft Connect - Product Feedback and Bug Reporting | Microsoft...
https://connect.microsoft.com/dashboard/info/
Thanks and Regards:
I. Suuresh Kumar- Microsoft Support.
42 additional answers
    2010-12-01T02:48:16+00:00
    Hi all,
    Pulseaudio seems to have been ported on Windows XP, but first, it was a pre-alpha work (if I well understood) and second, Microsoft seems to have changed something in the way the sound stream are handled since Vista, therefore, PulseAudio under Windows is broken.
    I think that Microsoft should give a try to implement it, as said before, on Ubuntu it works flawlessly but needs a good GUI.
    2010-12-01T12:43:58+00:00
    It is posible but very difficult to set up and you risk to have conflicts between the two devices.
    You can, for example, use your on-board sound for Windows Sounds and a soundcard or other device for an app that ALLOWS you to choose an input/output device (a DAW, for example, WMP (I beleive).
    It is also possible to connect from the line out of your on-board device (line out) to the other device (line in) to record streaming audio.
    My personal experience is to advise against it unless you really know what you're doing.
    Good luck,
    Jerry
    2011-04-22T00:51:24+00:00
    Wow the #1 OS (hopefully not much longer) says it's by design.  What a joke!
    This is why ubuntu/linux/android will dominate you.  BECAUSE THEY LISTEN TO THE USERS!  Keep telling us its by design and see how much longer you reign.  I'm disgusting by your attitude that this is the way it is and nothing can be done.  This issue would be resolved in less than 24 hrs on any ubuntu support page.
    2011-08-20T07:28:37+00:00
    "By-design" means "deliberate".
    In other words, Windows will only output to one sound card because Microsoft want it to only output to one sound card.
    "nothing much we can do from our end" therefore means "we don't wish to change this"
    One way around this is to use Virtual Audio Cable (http://), which can be set up to do what you want.
