Warner Music CD's sound is distorted on Dell Windows 7 computer
2010-02-19T14:31:22+00:00
I have a new Dell computer operating on Windows 7. Some cd's will not play or download on Windows Media Player or iTunes as the sound is totally distorted. These same cd's were fine on my old Dell with Windows XP. The cd's also play on Hi Fi's and other computers without any problems. Is this a problem with Windows 7? (all the cd's seem to be produced by Warner Music or their associated companies).
Any help would be appreciated.
2010-02-24T01:00:15+00:00
Hi ASTRA52,
I would suggest you to run the Hardware and Devices troubleshooter.
Open the Hardware and Devices troubleshooter by clicking the Start button , and then clicking Control Panel. In the search box, type troubleshooter, and then click Troubleshooting. Under Hardware and Sound, click Configure a device.‌  If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
http://windows.microsoft.com/en-us/windows7/Open-the-Hardware-and-Devices-troubleshooter
I would also suggest you to install the latest sound drivers compatible for Windows 7 from the manufacturer’s website.
http://windows.microsoft.com/en-US/windows7/Tips-for-fixing-common-sound-problems
You may also refer the below mentioned link.
http://support.microsoft.com/kb/316992
Hope this information helped!
 Thanks and regards,
 Fouzan – Microsoft support.
 Visit our Microsoft Answers Feedback Forum
 http://social.answers.microsoft.com/Forums/en-%20US/answersfeedback/threads and let
 us know what you think.
70 additional answers
    2010-12-02T00:54:52+00:00
    Still, you should return it to HP and ask them to replace the CD drive with a different brand and model that actually works.
    Otherwise they will never care and continue shipping these pieces of krap. Burn a copy of the Warner CD so they can test the new drive. Other posters in this thread returned their computer to Dell, they switched the CD drive, but with the exact same model, which of course didn't work any better.
    2010-12-13T01:58:40+00:00
    I have a very similar problem, but reading through this thread the single common factor seems to be that the CDs are distributed by the Warner Music Group (an AOL Time Warner Company).
    I have an HP Mini netbook, running Windows 7 Starter.  Being an HP Mini, there's no room for an internal optical drive, so I have an external USB2.0 Lacie portable DVD/CD +/- RW (click here).
    I ripped a lot of CDs to M4A using iTunes, and uploaded them to my Nano.  Over time I noted that some albums had a terrible crackling sound and were essentially useless (like really bad static on a long-wave radio or something).  This was only on a small number of CDs, so I figured that something may have gone wrong with the rips.  I picked one CD (Jet, "Get Born", distributed by guess who...Warner), and tried to re-rip it.  That failed.  Just to check my sanity, I played the CD in my good-ol'-fashioned stereo, and it worked fine.  Then I simply tried playing the CD directly using Windows Media player (so without ripping, just playing the CD) and noted that the problem still persisted.
    I then did some research on apps that might be able to fix CD errors and decided to try EAC (Exact Audio Copy), which seems to be well regarded as a rock-solid ripper when it comes to correcting errors.  I cranked up the "error recovery quality" to it's highest setting, and then left EAC ripping track 9 (because I felt the track title was appropriate ;)) to "FLAC" format.  So that took about8 hours!!!!  And it didn't work!  Note that EAC took 8 hours because it was trying very hard to correct what it was seeing as errors.  For other CDs (that don't have the Warner-crackle problem), it takes about 30 seconds to rip a track.
    I figured that this must be some DRM jiggery pokery on the CD, so I did some more research to establish what that might be.  The only stuff I could find was on theSony debacle with the XCP rootkit back in 2005, but Sony recalled loads of CDs and nobody (Sony included) appears to do that anymore (see here).  Nonetheless, I still did quite a bit of research and troubleshooting to verify that I definitely didn't have any malware associated with the XCP rootkit on my PC.  AFAIK, I'm clean, so I haven't tried to use any removal software.
    So my final thought was that the only thing I hadn't verified was whether I had an issue with my Lacie external DVD drive.  So, I decided to fire up my work laptop; a Lenovo Thinkpad T400 running WinXP Pro.  I put my Warner CD in the internal optical drive, and played the disc directly from Windows Media Player.  The CD played perfectly!
    That left me thinking that either my external Lacie drive was at fault, OR that it could be a Windows 7 problem (since my work laptop is an XP beast).  So, my final test was to plug my external drive into my work laptop and try to play the CD on that.  Guess what?  The sound quality was terrible again.
    It would appear to that my external Lacie drive doesn't like Warner Music Group CDs.  I checked the discs and their covers and none of them have the "Compact Disc Digital Audio" logo on them anywhere.  This means that they don't conform to the "Red Book" standard.  I can only assume that means that Warner are pushing out non-standard format discs, so all bets are off with regard to what drives they will play in!  I've tried finding some updated drivers and firmware for my Lacie drive, but I haven't managed to find any...everything seems to be on the latest available release.
    At this stage, my frustration is targeted at Warner, and as I said at the start of this post...looking at everyone else's comments throughout this thread, they appear to be the one common component.  If there are any law-talking-guys out there who think there's any case to bring against Warner, I'm happy to provide testimony ;).
    ATB, Chunky
    2011-01-14T22:02:13+00:00
    Window 7 has a lot to answer for!Ihad a new PB (AMD Turion ii x2 M500) laptop for christmas with windows 7.
    I had a old compaq 10 years old previous,with no problems playing or downloading discs.
    Now trying to download CD Paolo Nutini - These Streets (Atlantic) and BA Robertson The Platinum Collection(Warner) i have a distored sound on normal playback on laptop and within itunes and pod. I have also tried various other disc which were fine on old lap top and have problems with them on new.
    Surely microsoft should be seriously looking into a fix for this problem as there seems to be no real answers on forum.
    When reading the forum everthing points to windows 7.
    So come on microsoft we all pay hundreds of pounds for your products please find us a fix!!!!
    2011-01-15T00:35:39+00:00
    You misread the forum: Everything points to optical drives with defective firmware, which can't be changed by MS.
    An external drive of a different brand on the same Windows 7 laptop plays the same distorted CD fine.
    1. Post the brand and model of your optical drive in this thread for reference. You can find it on either:
        - Control Panel|Device Manager|DVD/CD-ROM drives, or
        - All Programs|Accessories|System Tools|System Information|Components|CD-ROM
    1. Check on both the laptop and optical drive manufacturers web sites that there is no available BIOS or firmware updates available for your system. If that's the case, download and install the latest versions.
    2. Burn a copy of your CD and check that the copy also plays distorted on your laptop and fine on someone else's.
    3. Return your laptop together with the copy of your CD to the laptop manufacturer, or just the CD if they ask.
        Ask them to play the CD after they replace the drive with a different brand or model as a sanity check.
    Most people returned their laptops without sending the CD for verification and got the same problem back.
    OEMs should have some sort of components black list to avoid these known issues... :(
