Microsoft Mouse 5000 Scrolling wheel problem and windows 7
2009-12-16T07:07:41+00:00
I've purchased a Microsoft Mouse 5000 recently and from day one i realized that the wheel behavior was weird.
For example in Winamp i can scroll up in the playlist but i have to turn the wheel several times downwards before it scrolls anything.
Also i noticed that the scrolling wheel behaves weird in photoshop when zooming and other programs, i tried the windows seven Intelipoint drivers for the 64 bit version witch i have, with no improvement whatsoever.
I have Windows 7 Ultimate RC (i dont remember the RC Version)
Thanks in advance.
2009-12-19T01:59:27+00:00
This apparently is dependant on the type of Microsoft Mouse you have.
I have a desktop and a laptop.
Desktop uses an old Intellipoint 3.0 while the laptop has a wireless Explorer Mini Mouse.
In the same applications on either machine the scrolling will be different.
The Intellipoint 3.0 will work everywhere as it should while in the same application the Explorer Mini Mouse will just flat out not scroll at all. But it depends on where in the application it is that I'm trying to scroll.
Example:
Microsoft Money:
• ABLE to scroll on Options screen, and dialog boxes.
• NOT able to scroll the account Registrar (really annoying btw)
Xara Xtreme (Imaging program)
• ABLE to scroll in options and dialog boxes, and lists (font selections, etc)
• NOT able to scroll on the main display (similar to Photoshop zooming / panning if ctrl is held while scrolling, the zoom is changed)
But, if I use switch my Intellipoint to the laptop, and use it on the same applications WITH THE SAME DRIVER PACKAGE INSTALLED (just switch which mouse I'm using in the Microsoft Mouse settings) then I can scroll all I want.
Unfortunately I've gotten used to moving to the scroll bar in certain places... but that is REALLY IRRITATING and causes more frustration than the mouse is worth sometimes.... I've had this problem for over a year, and I keep hoping that a new driver update will fix it... unfortunately it hasn't.
PS. I dont' know about you, but I really hate searching through Microsoft's "support" pages. Each page seems so Irrelevant to the terms ya searched for... ...makes things really hard to get figured out.
70 additional answers
    2010-01-19T20:51:15+00:00
    Win7-Geek - you are a genius!  Switching the type of mouse in the mouse properties is IT!!  I have not been able to scroll normally in Illy and Photoshop for a long time.  Thanks for the tip!
    2010-01-10T15:27:11+00:00
    I'm having the same problem
    scroll wheel is OK in
        Internet browser IE and Fire Fox
    scroll wheel is NG in
        SourceInsight (Text Editor program)
        uVision (Keil IDE program)
    PS
    I am using Microsoft Wireless Mouse 5000 + Keyboard
    OS Window7 64 bit (updated all patched)
    (I have tested with and w/o Microsoft InteliPointer too)
    If Microsoft staff can't figure and solve this problem maybe i must find other solution.
    2010-01-10T08:46:23+00:00
    I'm having the same problem. All games will not record the scroll wheel's action. Directx problem?
    It WILL record the scroll action, but you have to scroll it REALLY fast in order to get a response.
    Open a browser, and it smoothly scrolls down the page, very nice.
    Tried adjusting all scroll settings/reinstalling driver/unplugging/rebooting/hitting head on keyboard. Nothing will get the mouse to work right.
    My Guess --> It's a Driver BUG
    2010-01-07T02:30:55+00:00
    Ditto here. I built a new Windows 7 (64bit) machine late last year and connected the Wireless Comfort Keyboard/Mouse 5000; the scroll wheel "performs" erratically depending what program I'm using. It scrolls vertically in MSWord 2003, Firefox, and CS3 Bridge, but it won't work to change values in CS3 or Silkypix. It's a royal headache.
