System backup error [0x80041321]
2009-09-03T14:39:56+00:00
I am getting reminder to do system backup, when I attempt to do just that I receive message:  the task image is corrupt or has been tampered with [0x80041321].  I cant backup anything now and am worried.  Any help out there?
Windows for home | Windows 11 | Recovery and backup
    2011-12-16T23:11:49+00:00
    I believe the backup task that you have got corrupted somehow and is causing this issue.
    I suggest you try the following:
    1. Go to task scheduler (run taskschd.msc from RUN dialog OR from a command-prompt)
    2. Navigate under Task Scheduler Library->Microsoft->Windows->WindowsBackup folder
    3. Delete AutomaticBackup task
    4. Delete Windows Backup Monitor task
    5. Try to re-configure file backup
    In case you do not find these tasks in task scheduler UI, suggest doing the following:
    1. Open an elevated command-prompt
    2. cd %windir%\system32\tasks\Microsoft\Windows\WindowsBackup
    3. del AutomaticBackup
    4. del "Windows Backup Monitor"
    Let us know if either of these workarounds was helpful.
    Regards.
    Sreekanth.
    Howdy,
    These steps still do not work as of 12/16/2011.
    NurdBurd
    2012-03-07T14:49:14+00:00
    How do you re-configure file backup?
    2012-03-07T18:35:41+00:00
    It didn't work.  I use French version of Windows anyway and have been in touch with someone to resolve issue in January.  Too busy lately to look into question.  still getting popup icon reminding me to do backup though  Problem persists
    2012-10-31T04:17:58+00:00
    Yes, I tried it
    It worked for me. Thank you so much.
    2013-06-03T17:59:14+00:00
    Jak ponownie skonfigurować kopię zapasową plików?
