System backup error [0x80041321]
2009-09-03T14:39:56+00:00
I am getting reminder to do system backup, when I attempt to do just that I receive message:  the task image is corrupt or has been tampered with [0x80041321].  I cant backup anything now and am worried.  Any help out there?
Windows for home | Windows 11 | Recovery and backup
    2016-12-30T07:35:02+00:00
    I tried this and had the same results as the others who tried and it didn't work.
    Everyone having the issue concerning the command prompt and "Access Denied" is being displayed.
    When you attempt to open your command prompt you MUST right click and open as an Account Administrator. This will give you Access to perform any and all tasks in your O.S..
    2017-02-21T01:41:26+00:00
    This solved my problem but only through the second option. To explain in Windows 7 in plain language (since some people might not understand what elevated command prompt means).
    1. Dbl click on C drive
    2. Dbl click on Windows folder.
    3. Dbl click on System32 folder
    4. Same on Tasks
    5. Same on Microsoft
    1. Same on Windows.
    2. Same on WindowsBackup
    3. Now you'll see the 2 files (windows backup monitor and re-configure file back up).
    4. Select them both and delete.
    Now go back to automatic back up and set it up. It worked for me. If you do not know where to find that, just put "back up" in the start search box
    2017-07-06T21:18:00+00:00
    You ROCK. The command prompt worked.
    2017-08-12T12:39:39+00:00
    2017-11-04T05:10:53+00:00
    Switched from Win 7 home premium to Window 10.  Mistake.  Switched back to Win 7.  Now can't use backup. Keep getting message "The task image is corrupt or has been tampered with (0x80041321).
    How do you "reconfigure file backup"?
