Followed steps 1 delete AutomaticBackup
2 delete Windows Automatic Monitor
Close everything open control panel and select Configure Windows Backup.
Worked for me.
Thanks.
I am getting reminder to do system backup, when I attempt to do just that I receive message: the task image is corrupt or has been tampered with [0x80041321]. I cant backup anything now and am worried. Any help out there?
Worked for me.
Thanks.
YES - this works - thank you.
The fix provided by David Vinod (a/k/a/ Sreekanth) worked. I followed the second 5 steps. Backing up now. Thank you!
Back up Code 0x80041321 - nothing worked
I plugged in my external hard drive F/ - clicked on computer in start and double clicked on C Drive - all the items came up . On the left Desktops ect. - left click and right click each one and send to external drive. On the list on the right - left click on the first item hold the shift key down and scroll to the last item and click on it - all items are highlighted - right click - send to back up drive
Head over to this site. They deal with the "Access denied" issue:
http://www.windowsxpregistrycleaner.com/0x80041321-error-win7-system.html
In case you do not find these tasks in task scheduler, I would suggest you to follow the steps below:
1. Click on Start; in the start search type cmd.
2. Right click on cmd.exe and “Run as administrator”
3.
cd %windir%\system32\tasks\Microsoft\Windows\WindowsBackup <br><br>del AutomaticBackup <br><br>del "Windows Backup Monitor" 4. Restart the backup again by opening “Backup and restore center” from the Control Panel”.
Thank you had similar problem but your solution worked using the cmd.exe "run as admin". Now my windows back up is back to normal.
