System backup error [0x80041321]
2009-09-03T14:39:56+00:00
I am getting reminder to do system backup, when I attempt to do just that I receive message:  the task image is corrupt or has been tampered with [0x80041321].  I cant backup anything now and am worried.  Any help out there?
Windows for home | Windows 11 | Recovery and backup
    2016-06-01T10:24:25+00:00
    I just had the same 'image corrupt' message.
    Since I last backed up, I have, by accident, downloaded W10 and reverted back to W7. This in itself threw up several problems, but I am wondering if W10 is the culprit here too?
    2016-06-01T18:46:29+00:00
    W10 is indeed the problem. W10 will install itself by default if you do not take action on every 'reminder' to prevent it. This is illegal in the UK, don't know of others though. I paid for windows 7 on my PC, I expect to keep it as long as I want without interference from MS. Who the **** do they think they are forcing this change. I'm still waiting for someone to start a group action to join, as MS seemingly have no interest in putting this right.
    2016-06-06T03:30:39+00:00
    I just recently encountered the same (0x80041321) problem along with getting the same corrupt "Task Scheduler-Corrupted Task Image" message and the same "Command Prompt-Access Denied" message.
    I was able to overcome the "Command Prompt-Access Denied" issue by going around 3 pages deep into the replies on this web site and following the instruction in the reply from "SuzanneK sent in on September 03, 2015".
    Just remember to press the Return button after entering each of the three individual lines of information.
    After completing all 4 of her instruction points I logged out and restarted my PC then plugged my External HD back in and was able to do my back up.
    2016-06-11T14:13:02+00:00
    SuzanneK you're a star.
    I was experiencing this backup error, it appears like many others after my machine was hijacked by MS and Windows 10 was installed despite my wishes. I immediately went back to Windows 7 by rejecting acceptance of the Windows 10 terms and conditions but then started getting this backup error.
    I followed SuzanneK's excellent instructions (2 Sept 2015) and am backing up at this very moment.
    2016-07-23T19:08:10+00:00
    Thanks Sreekanth!
    I had the same problem and the second solution worked for me: I opened cmd as administrator and did what you wrote.
    helped me very much!
