System backup error [0x80041321]
2009-09-03T14:39:56+00:00
I am getting reminder to do system backup, when I attempt to do just that I receive message:  the task image is corrupt or has been tampered with [0x80041321].  I cant backup anything now and am worried.  Any help out there?
Windows for home | Windows 11 | Recovery and backup
    2009-09-04T12:07:47+00:00
    I believe the backup task that you have got corrupted somehow and is causing this issue.
    I suggest you try the following:
    1. Go to task scheduler (run taskschd.msc from RUN dialog OR from a command-prompt)
    2. Navigate under Task Scheduler Library->Microsoft->Windows->WindowsBackup folder
    3. Delete AutomaticBackup task
    4. Delete Windows Backup Monitor task
    5. Try to re-configure file backup
    In case you do not find these tasks in task scheduler UI, suggest doing the following:
    1. Open an elevated command-prompt
    2. cd %windir%\system32\tasks\Microsoft\Windows\WindowsBackup
    3. del AutomaticBackup
    4. del "Windows Backup Monitor"
    Let us know if either of these workarounds was helpful.
    Regards.
    Sreekanth.
    2009-10-29T03:53:33+00:00
    How do you re-configure file backup?
    2010-12-20T04:39:08+00:00
    THX!!!
    This hepls for me!!!
    2010-12-23T00:14:37+00:00
    Hi Sreekanth
    Neither method works for me, When I try to run task scheduler It gives me the corrupted task image message,so I cannot get any further. And when I try the command prompt method it says access denied....
    Any help with this woould be appreciated.
    Ted Salzman
    *** Email address is removed for privacy ***  or *** Email address is removed for privacy ***
    2011-01-03T08:17:38+00:00
    The same happens for me too.  I have two external hard drives which I can save to.  I have turned on one and then the other hoping that I could at least save to one of them .. no luck.
    Please can you throw some light on this error asap
    CelticDesign
