Speaker icon has a Red X on it, "no audio output device is installed".
2009-03-15T21:20:24+00:00
original title: No audio output device is installed.
I have done nothing different to my computer but noticed yesterday that the speaker icon in the system tray has a red and white "X" over it and says that "no audio output device is installed." I have Windows Vista. When I go to my control panel and click on "Sounds and Hardwar," and again click on "Sound," it tells me that "No audio devices are installed." Yesterday I went to --> All programs --> Accesories --> System Tools --> System Restore and I did a system restore that way. After my computer re-started, the audio problem was solved but somehow my anti-virus protection was no longer installed. I fixed this with the McAfee support online chat and the audio was also working all day yesterday. However, today, it again says that "no audio output device is installed," and I do not want to restore my system again and have to deal with the anti-virus software going haywire again. Is there another way to fix this? Please help me. I have looked this up on other support sites and have found the answers too technical for me to understand. I have a one-year-old Toshiba Satellite M205 with an Intel Centrino processer and Vista with Service Pack 1 installed although I don't know if that is important information or not. My computer has a sticker on it that says "Dolby Sound Room," whatever that means. Thanks in advance!
2009-03-16T13:45:31+00:00
Hi m_kelsey,
It sounds like you might have an audio driver that isn’t working properly, please do the following:
1.       Click Start
2.       In ‘Start Search’ type Device Manager, press Enter (provide administrative credentials if prompted)
3.       Click the “+” next to Sound, video and game controllers to drop down the menu
4.       Check the status of any device listed in that category by right-clicking that device, clicking Properties, and then under the General tab check what it says under “Device status”. Let us know what the status was.
5.       Then check all the devices (especially any that had a problem under “Device status”) listed in this category for updated drivers by right-clicking that device and then clicking Update Driver Software… (this step may take a moment so be patient).
Get back to us with your results so that we can further assist you if need be. We look forward to hearing back from you.
Brian
190 additional answers
    2011-10-13T08:17:57+00:00
    I have fixed mine, the problem was  the "High Definition Audio Device" driver, which is from Microsoft, it stopped the installation of realtek software/driver.
    I have tried to remove(delete from computer etc) that driver, "High Definition Audio Device" , then the computer will show me the message to install Reatek driver etc. the adio is working now (occationally still showing "No audio output device is installed" even it's working)
    2011-10-16T14:22:30+00:00
    hi
    i have the same problems in this thread with a couple of exceptions:
    1. "Sound, video and game controllers" does NOT show up in "Device Manager" but is found after choosing the "Add Legacy Hardware" option.
    2. Updating the HD Audio driver for my Realtek ALC268 sound card FAILS with "Invalid Access to Memory Location".
    3. The "High Definition Audio Controller" is present under "System Devices".
    Are there any solutions to getting by the "invalid access" issue because that seems to be the problem?
    2011-10-18T18:27:40+00:00
    hi
    i have no audio output device is installed . there is no sound video and games controllers and i have tried everything and nothing has worked do you have a solution i have High Definition Audio device when i try and install it back it does not work SOMEONE PLEASE HELP ME .
    2011-10-21T00:13:49+00:00
    hey Karanveer,
    i got tired of waiting for an answer so i was left with little recourse but to format/re-install aka the standard windows fix.
    before i did that though i gave the laptop a good whack.
    i now have sound.
    i'm guessing the soundcard shook loose at some point and my last act of desperation re-seated the card (which is not integrated into the laptop).
    i still don't have the Realtek management console but i didn't know it existed before so it doesn't matter now.
