Speaker icon has a Red X on it, "no audio output device is installed".
2009-03-15T21:20:24+00:00
original title: No audio output device is installed.
I have done nothing different to my computer but noticed yesterday that the speaker icon in the system tray has a red and white "X" over it and says that "no audio output device is installed." I have Windows Vista. When I go to my control panel and click on "Sounds and Hardwar," and again click on "Sound," it tells me that "No audio devices are installed." Yesterday I went to --> All programs --> Accesories --> System Tools --> System Restore and I did a system restore that way. After my computer re-started, the audio problem was solved but somehow my anti-virus protection was no longer installed. I fixed this with the McAfee support online chat and the audio was also working all day yesterday. However, today, it again says that "no audio output device is installed," and I do not want to restore my system again and have to deal with the anti-virus software going haywire again. Is there another way to fix this? Please help me. I have looked this up on other support sites and have found the answers too technical for me to understand. I have a one-year-old Toshiba Satellite M205 with an Intel Centrino processer and Vista with Service Pack 1 installed although I don't know if that is important information or not. My computer has a sticker on it that says "Dolby Sound Room," whatever that means. Thanks in advance!
2009-03-16T13:45:31+00:00
Hi m_kelsey,
It sounds like you might have an audio driver that isn’t working properly, please do the following:
1.       Click Start
2.       In ‘Start Search’ type Device Manager, press Enter (provide administrative credentials if prompted)
3.       Click the “+” next to Sound, video and game controllers to drop down the menu
4.       Check the status of any device listed in that category by right-clicking that device, clicking Properties, and then under the General tab check what it says under “Device status”. Let us know what the status was.
5.       Then check all the devices (especially any that had a problem under “Device status”) listed in this category for updated drivers by right-clicking that device and then clicking Update Driver Software… (this step may take a moment so be patient).
Get back to us with your results so that we can further assist you if need be. We look forward to hearing back from you.
Brian
190 additional answers
    2009-11-17T23:09:55+00:00
    Hi - yesterday, no audio...husband selected VIA high def audio for speaker set up instead of SRS, and it worked.  Today, Same problem and no settings changed at all.  Have done what was suggested by Brian, to no avail.  Have done advanced troubleshooting, nothing worked.
    Went online for Asus support (I have Asus pc), and got response 'no one avail...leave email msg' and they'd try to reach me w/in about 48hours.  I'm out of books, and now my pc!  Help!!!  pls...
    Thank you - Dana
    2009-11-18T18:48:57+00:00
    I have the same problem!  had sound last nigth. there was a vista update and this morning no sound. No Audio Output Device. I did the above and and drive is up to date.
    Got this error msg.
    This device is not working properly because Windows cannot load the drivers required for this device. (Code 31)
    Please Help
    Ryan
    2009-11-18T21:41:49+00:00
    Hi RagganBoBaggan,
    Use this method to load the drivers :
    Control Panel - Device Manager - SOUNDS - look for HD Audio - Mine says RealTek High Definition Audio
    (that is an example and yours may have an entirely different name/maker).
    Write down description make and model - double click on it - drivers tab - write down version. Now
    Click UPdate Drivers which may not do anything as MS is far behind certifying drivers. Then RIGHT
    CLICK on it and UNINSTALL - REBOOT - this will rebuild the driver stack.
    1st go to system maker's site and look for latest driver Download - SAVE - go to right click on and RUN AS ADMIN
    (This is your fallback.) REBOOT after each driver installation.
    NOTE : Sound drivers often rollback so check the version after installation and the reboot tosee if the version you installed is there, if not repeat the install - reboot until it is. It can takeseveral tries depending on how many rollbacks it does.
    Then do same for Device Maker's site.
    Manually look at manufacturer's sites for drivers - and Device Maker's sites.
    http://pcsupport.about.com/od/driverssupport/ht/driverdlmfgr.htm
    How to Install a Device Driver in Vista Device Manager
    http://www.vistax64.com/tutorials/193584-device-manager-install-driver.html
    Error “the Audio Service Is Not Running” When Opening the Volume Mixer in Vista
    http://www.winhelponline.com/blog/error-the-audio-service-is-not-running-when-opening-the-volume-mixer-in-vista/
    Also Right Click Speaker near clock - Playback Devices - right click in the box area - check
    Show disable and disconnected devices. Highlight speaker and on the lower Right click Properties
    check settings for Device Usage enabled and so on. Also do same for Configure on Lower Left of
    that box.
    In Control Panel you can also look for an Audio Manager along with the Sound Settings.
    Problems with sound and audio or no sound - a Mr Fixit
    http://support.microsoft.com/gp/no\_sound
    Tips for fixing common sound problems
    http://windowshelp.microsoft.com/Windows/en-US/Help/1e87a3e8-c0e8-49af-980f-9eb6686f42d21033.mspx
    Speakers and other audio output devices
    http://windowshelp.microsoft.com/Windows/en-US/Help/a43f3a31-6d9f-49d1-be22-e2f47b8b1f2c1033.mspx
    How to Enable Hidden Audio Devices in Vista
    http://www.vistax64.com/tutorials/143447-audio-device-enable-hidden-devices.html
    How to troubleshoot sound problems that you experience after you install a Windows Vista Service Pack
    http://support.microsoft.com/kb/948481
    Hope this helps.
    Rob - Bicycle - Mark Twain said it right.
    2009-12-09T17:54:36+00:00
    I have read this fix several times and it has helped alot of people but I have a problem. When i go to device manager there is nothing that says "sounds, video and game controllers". It is like it has been completely erased from my computer. Can you please tell me what I can do to fix this?
