Right click 'Open With' Command missing. Help Please.
2009-09-21T20:08:24+00:00
I realised a few days ago that the right click context menu 'open with' command is missing. However its there at the top of the window on the 'menu bar' or whatever.
Not sure how it happened. Maybe when i installed MS .Net Framework 3 SP1 or maybe when I cleaned registry with CCleaner.
I need to get it back please. Could u tell me how??? thanks.
2009-09-22T12:20:29+00:00
Hi, scurvy:
By design, the Open With menu option is not available when you right-click executable files (.cmd, .bat, .pif, .scf, .exe, .com, or .scr), or shortcuts to executable files.
If you've lost the Open With menu option for ALL file types, including non-executable files, follow this steps:
  1. Click Start, All Programs, Accesories, Notepad.
  2. Copy and paste this text:
Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\*\shellex\ContextMenuHandlers\Open With]
@="{09799AFB-AD67-11d1-ABCD-00C04FC30936}"
  1. Click File, Save As, name the file "OpenWith.reg" (WITH THE QUOTATION MARKS) and click OK.
  2. Now double-click OpenWith.reg, click Continue, Yes, OK, and see if the problem is solved.
P.S: My personal advice is not to use ANY registry cleaner on the system.
Microsoft MVP Windows Desktop Experience
100 additional answers
    2011-09-27T19:57:10+00:00
    Same here, on a bunch of batch files I have created to backup my files. Double clicking runs the batch file, however I want to be able to select the text editor to open it for edit. It is now notepad, but I want an advanced editor that I have purchased to open it for editing instead??
    2011-06-25T21:16:00+00:00
    Thanks for this solution - worked for me......Rgds
    2011-06-15T00:17:27+00:00
    YOU ARE A LIFE SAVER!!! I was trying to delete a right click menu for something called PakkISO and I accidentally deleted this, without backing up against all the warnings.... Thank you so much for this fix man.
    2011-05-17T14:54:16+00:00
    Hi, I tried to run this script with the amendment "Windows Registry Editor Version 6.1" and sadly it's not recognised as a Reg key. I then did a system restore with no luck, ( tried a rollback to the original state but got an error ) I then replaced Reg keys removed with CCleaner & still I have no "Open With" option on my R-click when opening a JPEG file for instance.
    Can anyone offer any assistance please ?
