USB flash drive prompts with "Write Protected" message.
2010-06-25T00:56:28+00:00
I have recently purchased a 32gb usb flash drive. I have been using it ok until 3 days ago. I now get a message saying "Write Protected". There is no write protection switch on the device. How do i remove the write protection.
2010-06-25T21:03:53+00:00
You can remove write protection from your usb flash drive using the below method:
a. Open start menu, in the search bar type regedit and press enter. This wil open the registry editor.
b. Navigate to the following path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
Note:
If the registry key StorageDevicePolicies does not exist, you will need to create it manually.
c. Highlight StorageDevicePolicies, and then create a New DWORD (32-bit) Value named as WriteProtect.
d. Double click the key WriteProtect in the right window and set the value to 0 in the Value
Data Box and press OK button
e. Restart your computer and try copying files into your USB drives.
Important Note:
Sometimes this problem is caused by two Windows registry entries that have become corrupted. To fix the problem, you have to use Registry Editor to delete the corrupted registry entries.
However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs.
For more information about how to back up and restore the registry, follow the steps as in the KB Article:
http://support.microsoft.com/kb/322756/
Hope this helps.
Thanks and Regards:
Shekhar S - Microsoft Support. Visit our Microsoft Answers Feedback Forum and let us know what you think.
If this post helps to resolve your issue, please click the "Mark as Answer" or "Helpful" button at the top of this message. By marking a post as Answered, or Helpful you help others find the answer faster.
66 additional answers
    2013-10-15T05:35:35+00:00
    what do you mean by create a New DWORD (32-bit)???? what is a DWORD? are you creating a new file with that name? and i am running win 7 64 bit.
    2013-10-06T09:14:14+00:00
    I have tried this method a number of times, and each time it has not worked. What other options are there??
    If you read from the beginning of the thread, you will see that there are a number of options.
    I have tried every known method, using other operating systems and low-level format tools.  Originally, I was trying to fix the USB sticks, but now I've given that up and it's just out of interest to see if a solution can ever be found.
    Some work for corrupted System Policies.  However, there are a lot of cases where there are no known means to make the USB drive 'readable' - see my earlier posts.
    2013-10-05T22:46:12+00:00
    2013-07-17T01:55:35+00:00
    I tried this on two different computers and it did not work on either one.  First was Windows 7 64 bit and the other was Windows 8.1 64 bit. Mine is an 8 gig ScanDisk.  I had previously made it a bootable USB drive using DiskPart.  I first was just wanting to add data to it and received message that it was Read Only so tried to format it and it won't do it.  On the Windows 7 system I went back into Diskpart and did a Remove to unassign it and now it won't even show as an available drive.  Did a recover and it still doesn't show.  It does show as available drive on the Windows 8.1 set but still will not format.  Still works as a bootable drive but not what I want to use it for right now.  It is not even a week old at this point.
    thanks for any help
    Doc
