USB flash drive prompts with "Write Protected" message.
2010-06-25T00:56:28+00:00
I have recently purchased a 32gb usb flash drive. I have been using it ok until 3 days ago. I now get a message saying "Write Protected". There is no write protection switch on the device. How do i remove the write protection.
2010-06-25T21:03:53+00:00
You can remove write protection from your usb flash drive using the below method:
a. Open start menu, in the search bar type regedit and press enter. This wil open the registry editor.
b. Navigate to the following path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
Note:
If the registry key StorageDevicePolicies does not exist, you will need to create it manually.
c. Highlight StorageDevicePolicies, and then create a New DWORD (32-bit) Value named as WriteProtect.
d. Double click the key WriteProtect in the right window and set the value to 0 in the Value
Data Box and press OK button
e. Restart your computer and try copying files into your USB drives.
Important Note:
Sometimes this problem is caused by two Windows registry entries that have become corrupted. To fix the problem, you have to use Registry Editor to delete the corrupted registry entries.
However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs.
For more information about how to back up and restore the registry, follow the steps as in the KB Article:
http://support.microsoft.com/kb/322756/
Hope this helps.
Thanks and Regards:
Shekhar S - Microsoft Support. Visit our Microsoft Answers Feedback Forum and let us know what you think.
If this post helps to resolve your issue, please click the "Mark as Answer" or "Helpful" button at the top of this message. By marking a post as Answered, or Helpful you help others find the answer faster.
66 additional answers
    2013-06-15T09:22:57+00:00
    Hi Shekhar S-
    Thank you for the comments.
    It really works for me-a BIG thanks!
    Though I noticed something different-when I went to the StorageDevicePolicies, the file named WriteProtect already existed, so I didn't have the need to create a new DWORD (32-bit).
    And I didn't even have the need to reboot the system. I understand that it may work differently for different set ups/computers.
    Thanks.
    Umang
    2013-05-20T13:38:46+00:00
    Shekar S (Support Engineer) did point out how to do this in the second postin this thread:
    Backup the Registry first (see this LINK for instructions).
    Then press the "Windows" key on your keyboard and type regedit (you don't need to click in the box) and press Return.
    Navigate to CurrentControlSet\Control and right click the panel to create a new key, as described in an earlier post.
    Call the new key StorageDevicePolicies, and then create a New DWORD (32-bit) named as WriteProtect.  Assign it a value of  0
    You should note that this does not work with some damaged drives, where the file system is corrupted, because Windows cannot 'see' the drive.
    If you are not satisfied that you are competent to make changes to the Registry, or back it up, you should ask someone else to do it for you, including perhaps by Remote Assistance.
    You can see how to use Remote Assistance HERE.
    2013-05-20T11:19:00+00:00
    how to create storagedevicepolice
    please explain
    2013-05-19T17:20:26+00:00
    Nope that not work ......still it remains "windows Delayed writing failed..." with yellow exclamatory mark symbol in right cornor!
    plzz help!
