Volume icon disappeared from my system tray, and the option is greyed out (won't let me check it) in the taskbar and start menu properties screen /Notification area
2010-04-21T14:17:02+00:00
I don't know how to get my volume icon back - can anyone help?  Thank you!
2010-04-21T16:39:22+00:00
 If any of the system icons are out, you can re-enable them as follows:
Right click on the taskbar and select properties. This will bring up the "Taskbar and start menu properties" tab. This is where you mentioned it was greyed out. That's fine...  From here you can click on customize button in the icons section. Locate the icon that you are missing and check status. The status type should read "Hide  icon and notifications", change this to "Show icon and notifications".
If this doesn't fix the issue you most likely have an issue with a group policy on your machine. This can be fixed by following the instructions on the following link:
http://www.mydigitallife.info/2009/01/01/fix-network-clock-volume-and-power-battery-system-icons-missing-with-disabled-or-grayed-out-check-box-options/
Hope this helps,
Steve <> Microsoft Partner
104 additional answers
    2017-05-10T21:19:16+00:00
    When I right click on the taskbar,  there is no "properties" tab.  When I click the gray arrow up^ on the task bar there is no icon that says sound or volume
    2017-03-20T17:05:05+00:00
    genius! Thank you! Simple solution that REALLY worked. Occam's Razor
    2016-11-17T18:49:33+00:00
    my volume icon disappeared, how cn I get it back
    2016-07-15T09:13:00+00:00
    sad to say that restarting explorer is the best solution. thanks
