Unable to create a system repair disc 0x80070057
2010-04-12T14:20:06+00:00
When I create a system repair disk,once click create button and error came out
original title: the parameter is incorrect ( 0x80070057)
Windows for home | Windows 11 | Recovery and backup
2010-04-13T12:11:00+00:00
Hi lew9789,
·         Which method did you follow to create the recovery disc?
i.           Boot the system by inserting Windows 7 installation disc.
ii.         When it gets to the main setup window, click on Repair from the lower left corner.
iii.       Select Command Prompt from the main Repair menu.
iv.        At the command prompt type in recdisc, then ENTER.
v.          You'll get the popup to choose which drive letter to create the Recovery disc to.
vi.        Have a clean DVD in the DVD drive and select start.
This should get your System repair disc created.
Regards:
Samhrutha G S - Microsoft Support.
73 additional answers
    2011-08-13T20:41:24+00:00
    Dear Sharkbyter,
    I just went to the link that you gave but now they are not letting anyone download the File do you know anywhere else I can get it.  I got an Acer Laptop but the CD got damaged and I am not in the US so I can not just call and ask for a new one.
    Any help would be great.
    King
    2011-08-28T23:27:00+00:00
    Hey - had the same problem. Was trying to burn System Repair disk - using some very nice (expensive) colourful Lightscribe discs - burnt some very nice pieces of worthless (expensive) ****, tore my hair out, cursed microsoft, kicked the cat (no i didn't really) then put a Lightscribe CD in the drive and it burnt perfectly. Checked it out - it booted/worked perfect. DVDR - no. CDR - yes.
    Question: Loads of people experiencing this problem. Why no answer from Microsoft??? This is a Microsoft forum right??? C'mon guy's, are you really so busy counting the dollars to bother with a simple reply?
    2011-08-29T00:11:30+00:00
    Should point out, further to my last entry - would categorically NOT recommend using anonymous Torrents as a form of downloading/creating a system disc, as proposed in a previous solution.  Use either your Windows 7 install disc or a recovery disc from a reliable source.  The NeoSmart forums <Removed> may be a possible solution.
    2011-08-29T00:29:54+00:00
    http://cybernetnews.com/windows-7-recovery-disc/ might also be a solution.  Searched and searched for solutions to this, including microsoft sites - result nothing.  Just  loads of people trying to make money out of windows users misery.  Point 1 - a lot of people have been unsuccessful in creating recovery discs from within Windows 7.  Point 2 - Microsoft need to accept this and create a download option for this situation or better still, fix this problem.
