Unable to create a system repair disc 0x80070057
2010-04-12T14:20:06+00:00
When I create a system repair disk,once click create button and error came out
original title: the parameter is incorrect ( 0x80070057)
Windows for home | Windows 11 | Recovery and backup
2010-04-13T12:11:00+00:00
Hi lew9789,
·         Which method did you follow to create the recovery disc?
i.           Boot the system by inserting Windows 7 installation disc.
ii.         When it gets to the main setup window, click on Repair from the lower left corner.
iii.       Select Command Prompt from the main Repair menu.
iv.        At the command prompt type in recdisc, then ENTER.
v.          You'll get the popup to choose which drive letter to create the Recovery disc to.
vi.        Have a clean DVD in the DVD drive and select start.
This should get your System repair disc created.
Regards:
Samhrutha G S - Microsoft Support.
73 additional answers
    2017-12-17T21:19:05+00:00
    There is another possible cause for this error when trying to create a system repair disc:
    cloud drive applications.
    Unmount/quit/close the cloud apps in the system tray, then try creating a system repair disc again.
