Unable to create a system repair disc 0x80070057
2010-04-12T14:20:06+00:00
When I create a system repair disk,once click create button and error came out
original title: the parameter is incorrect ( 0x80070057)
Windows for home | Windows 11 | Recovery and backup
2010-04-13T12:11:00+00:00
Hi lew9789,
·         Which method did you follow to create the recovery disc?
i.           Boot the system by inserting Windows 7 installation disc.
ii.         When it gets to the main setup window, click on Repair from the lower left corner.
iii.       Select Command Prompt from the main Repair menu.
iv.        At the command prompt type in recdisc, then ENTER.
v.          You'll get the popup to choose which drive letter to create the Recovery disc to.
vi.        Have a clean DVD in the DVD drive and select start.
This should get your System repair disc created.
Regards:
Samhrutha G S - Microsoft Support.
73 additional answers
    2014-09-13T20:45:35+00:00
    Should point out, further to my last entry - would categorically NOT recommend using anonymous Torrents as a form of downloading/creating a system disc, as proposed in a previous solution.  Use either your Windows 7 install disc or a recovery disc from a reliable source.  The NeoSmart forums <Removed> may be a possible solution.
    If Microsoft are too useless and lazy to provide functions that work; then the rest of us will have to do what we can. If that means spreading a virus to MS in the process by accident, then they are getting what is called Karma.
    2014-09-13T20:48:08+00:00
    It would be nice if we got some better participation from Microsoft in these forums.  The supposed answer does not address all the issues that people have found and reported in this thread.   It should be updated.
    I too found instances where you cannot create a system disk because some other software component is active and needs to be turned off (i.e. TrueCrypt) and it is disturbing to see some of these issues from an OEM installation.
    I would love to provide feedback, but the URL posted above results in Page Not Found.  Perhaps our expectations are just too high for Microsoft to provide quality products, services or support?
    Example of another Microsoft middle finger. Drag it out so that people give up and scream until LinuxMint 17 x64, happens. Ah, it did.
    2015-08-26T02:18:54+00:00
    This realy not solution... I want to create from windows not from instalation disk. If trought instalation disk of course we all can do.
    2015-08-31T05:46:40+00:00
    And then what do you do with the files that are created??? Trying to make a recovery disk.
