Unable to create a system repair disc 0x80070057
2010-04-12T14:20:06+00:00
When I create a system repair disk,once click create button and error came out
original title: the parameter is incorrect ( 0x80070057)
Windows for home | Windows 11 | Recovery and backup
2010-04-13T12:11:00+00:00
Hi lew9789,
·         Which method did you follow to create the recovery disc?
i.           Boot the system by inserting Windows 7 installation disc.
ii.         When it gets to the main setup window, click on Repair from the lower left corner.
iii.       Select Command Prompt from the main Repair menu.
iv.        At the command prompt type in recdisc, then ENTER.
v.          You'll get the popup to choose which drive letter to create the Recovery disc to.
vi.        Have a clean DVD in the DVD drive and select start.
This should get your System repair disc created.
Regards:
Samhrutha G S - Microsoft Support.
73 additional answers
    2010-04-23T15:52:47+00:00
    Hi Samhrutha G S,
    W7 Control Panel Home with System & Recovery folder. In the folder list with Backup & Restore. under this
    Backup & restore folder have " Create a System repair Disc " selection. Unfortunately, I follow the
    instruction step by step until click create button and this error occurred. I using HP notebook but I try
    create this disc in my friend compaq notebook was successful. So, I wonder what going wrong my window?
    Thank you
    Best regards,
    Lew
