No low battery notification and my computer always just shuts off, I have all the right settings on
2010-05-19T07:07:41+00:00
I purchased my laptop now for about 6 months and the most annoying part is that there is never a low battery notification before my laptop hibernates. It has never shown up once.
The battery meter is active and shown in my system tray. I have gone into power options, changed advanced battery options for low, critical, and reserve levels as well as turned ON low battery notification. In system tray properties > notification area > customize > I have also selected "show icon and notifications".
The windows 7 microsoft website as well as many other forums only suggest to do these 2 things. I HAVE done these two things, as they were the original settings when I bought this laptop new...what else can I do? Is there a patch, download, anything?! I would rather not have to install 3rd party software. I would just like my laptop to function properly. I am not a heavy gamer or student, I just use my laptop to surf the web and watch videos. I also use free Avira antivirus, if any of this is important to why a battery notification won't show up.
Edit: My friend and I bought the exact same computer on the same day. His shows notifications and mine doesn't, so I know it's possible.
2014-11-25T13:08:22+00:00
Just open your
"control panel"
and then "power option" then
"change advance power settings"
there select  the profile you want to active( power saver ,high performance etc.)
Then scroll down to "battery" expand it and find "low battery notification" and turn  "on" for both "on battery" and "plugged in"  and you will done.
Note :- not necessary to turn it on for "plugged in"
81 additional answers
    2017-01-08T19:02:19+00:00
    Had already done this numerous times, but did it again anyway.  Didn't work before and doesn't work now.
    2017-01-08T17:53:46+00:00
    I have the same problem as discussed over here. Some time after updating to windows 10 my Samsung does not warn me when the battery is low or critical. Just shuts down at 30-or-something-% left.. So annoying. I have ok+ computer skills, and have tried formatting the computer and also the advanced battery settings.
    Would appriciate any solutions. Thanks in advance :)
    2017-01-04T18:52:08+00:00
    No solution yet to my problem; none of my battery settings were at 0%.
    2017-01-04T18:51:27+00:00
    None of my battery settings are at 0%, so that's not the problem.  (But just out of caution, I restored the factory default percentages anyway.)  My notification was already on.  But it doesn't notify me, just shuts down.
