What do I do if my computer has no sound?
2009-08-25T01:35:30+00:00
2009-08-25T03:48:33+00:00
If your computer is having problems playing sound, try using the Playing Audio troubleshooter to fix the problem. It checks for common problems with your volume settings, your sound card or driver, and your speakers or headphones.
To open the Playing Audio troubleshooter:
1.       Click the Start button, and then click Control Panel.
2.        In the search box, type troubleshooter, and then click Troubleshooting.
3.       Under Hardware and Sound, click Troubleshoot audio playback.
4.       Follow the instructions in the troubleshooter.
2200+ people found this answer helpful.
79 additional answers
  1. Deleted
    2011-01-31T22:23:20+00:00
    Thank you for the imformation,managed to get my sound back.Now Ive got a continuouse jingle playing as well.
    2011-09-03T07:15:37+00:00
    salut je vien de format mon ordinateur et je installer le windows xp mais j'ai pas de audio sur mon ordinateur  sil vous plait si vous pou vez m'aidez
    2011-10-21T02:52:28+00:00
    I have no sound comming from my computer speakers. What can I do? I already tried audio
    troubleshooter, it didn't work.
