What do I do if my computer has no sound?
2009-08-25T01:35:30+00:00
2009-08-25T03:48:33+00:00
If your computer is having problems playing sound, try using the Playing Audio troubleshooter to fix the problem. It checks for common problems with your volume settings, your sound card or driver, and your speakers or headphones.
To open the Playing Audio troubleshooter:
1.       Click the Start button, and then click Control Panel.
2.        In the search box, type troubleshooter, and then click Troubleshooting.
3.       Under Hardware and Sound, click Troubleshoot audio playback.
4.       Follow the instructions in the troubleshooter.
2200+ people found this answer helpful.
79 additional answers
    2009-11-17T15:44:46+00:00
    I had this same problem and after doing some hard research, several hours later.. trying to go to my manufactor and trying to install old drivers from my old xp, and vista cd's and no luck, I simply went to cnet's websited for download and searched:
    SigmaTel4487.exe - SigmaTel Audio Driver Version: 5.10.4487
    Installed it and just like that, my speakers were once again recognized and I I saw them plugged in, I was on the verge of buying a new sound card since my current configuration is a sound card intergrated with my motherboad.  I actually bought one of the ebay USB sound cards for $4 as a last resort, too bad I wont get to use it anymore and I already wrote those few dollars off as a lost cause and I have not even receive the usb card.  Ohh well, you live an learn.  This was the only issue I had with windows 7, the no sound problem.  Other than that, my experience has been great and I will still recommend it.  I hope this helps some of you out there, enjoy!
    2009-12-09T03:59:08+00:00
    I have been trying for three days to correct this. I am getting tired of this loop and no answers. The sire reccomended by Chavez is not working. I got no disk with my laptop for vista or I would reload. I loaded the 32 bit version into my Toshiba with no problem, then the 64 bit into my new HP lost the sound.
    I know I am one of many people with this problem, why no answers yet??????
    2009-12-30T05:16:31+00:00
    Buy a Mac.
    2010-01-11T01:50:51+00:00
    I tried that already now no sound and I can't even get my media to work properly as I have no audio.
