What do I do if my computer has no sound?
2009-08-25T01:35:30+00:00
2009-08-25T03:48:33+00:00
If your computer is having problems playing sound, try using the Playing Audio troubleshooter to fix the problem. It checks for common problems with your volume settings, your sound card or driver, and your speakers or headphones.
To open the Playing Audio troubleshooter:
1.       Click the Start button, and then click Control Panel.
2.        In the search box, type troubleshooter, and then click Troubleshooting.
3.       Under Hardware and Sound, click Troubleshoot audio playback.
4.       Follow the instructions in the troubleshooter.
2200+ people found this answer helpful.
79 additional answers
    2016-09-28T13:53:28+00:00
    Go to the speaker on system tray in lower right hand corner. Right click on it. Select "open volume mixer".  Adjust all items to maximum sound. I found this out after months of searching.
    2016-11-26T11:13:57+00:00
    Sound does not work on Win 10 upgrade to HP desk top Pavilion. Troubleshooter says everything is fine. What is the fix?
    2016-12-26T05:32:53+00:00
    my computer has no sound, i tried making sure there was no hardware conflicts, i checked the connections, and i tried the troubleshooter. nothing worked. the wierd thing is it can still play MIDI files but no other sounds.
    2016-12-26T05:40:10+00:00
    The sound problem has been taken care off.
    Thank you,
    Roy
