Windows DVD Maker Aspect Ratio problems
2010-03-04T02:15:45+00:00
I am using the Windows 7 DVD Maker tool, and am experiencing some MAJOR issues.  I have a widescreen formatted AVI file I am trying to burn onto a DVD.  When I import the video, it doesn't matter which aspect ratio I choose the finished DVD is the same.  Menu shows video correctly, but the movie part is squeezed into a 4:3 with black bars on all four sides. it seems to be that Windows DVD Maker does not recognize the aspect ratio of the AVI file imported. Although the AVI file loads in Media Player in the widescreen format, the file listing in DVD Maker clearly shows in 4:3 aspect ratios for the same file, I may sure that Windows 7 DVD Maker is set up correctly on (16:9)
 I have wasted several DVDs attempting to use multiple configurations within DVD Maker and none have been successful. The dvd ALWAYS burns in 4:3 aspect ration regardless of the settings chosen under the options menu. This is definitely a bug in the program.
    2013-11-03T00:22:24+00:00
    no, there's no fix yet.... you have to continue using one of the work-arounds
    the problem happens because the use of MM2012 files in combination with Windows DVD Maker results in the aspect ratio tag of the ifo file on the disc being set to standard instead of widescreen..... work-arounds include not using MM2012 or editing the ifo file on the disc to change the tag  to widescreen.
    2013-11-03T11:15:59+00:00
    My original thread is shown below. This certainly worked for me and many others. Simply put you need uninstall MovieMaker version 2012 and install Version 2011.
    My original thread April 2013
    I have actually resolved the problem. It struck me that my problem only started when I updated my version of Movie MAKER (yes MOVIE MAKER). So on the search for an older version on the MS Website I found version Movie Maker v2.6, downloaded and installed. Next I downloaded a later version (2011) of Microsoft Essentials and then using DVD Maker,  I re-burnt a previous failed WMV file and Hey Presto! everything was back to normal. I can only assume that the latest version of Movie Maker(2012) somehow corrupts an important DLL or AX file. Incidentally I now have 2 versions of Movie Maker on my PC i.e. 2.6 and version 2011 (Build 15.4.3555.0308). Obviously I use the latter.
    I hope this helps. "
    2013-11-03T13:39:21+00:00
    That's a workaround... Not a fix.
    2014-06-15T13:55:44+00:00
    I was a little puzzled by this problem, too.
    Fortunately, I have been an electronics/computing enthusiast since a small boy, and it has become my profession, too, so I got to the bottom of this one.
    I created a PAL DVD in 16:9 format from 16:9 photographs using two computers in parallel running Window Live Movie Maker to create slideshow videos which I then merged into a single DVD using Windows DVD Maker under Windows 7. To get maximum clarity, I saved these as WMV video files with an aspect ratio of 1280:720, which is exactly 16:9. This made it easy to see what was wrong.
    Of the two computers which created the video files files, one was running Windows Live Movie Maker version 2012 (Build 16.4.3505.0912) under Windows 8.1, and the other was running an older version, version 2011 (Build 15.4.3538.0513) under Windows 7.
    Both of the video files appeared to have the same settings, and display correctly under Windows Media Player and the popular VLC video player.
    In Windows DVD Maker under Windows 7, the file from the Windows 8 machine showed as being narrower than the file from the Windows 7 machine, and the rendered DVD had the same issue: the file from the Windows 8 machine was squashed horizontally to fit into a 4:3 ratio.
    I found that the open-source video analysis program "gspot" was able to diagnose the problem for me. The video codec used by both versions of Windows Live Maker appears to be the same... WMV3 WMP v9 (VC-1 Simple/Main), and the dimensions are both 1280x720 - but there is a difference, which appears to make the difference to Windows DVD Maker. There are parameters called sar, par and dar, which are Storage aspect ratio, Pixel aspect ratio, and Display aspect ratio. See http://en.wikipedia.org/wiki/Pixel_aspect_ratio for an explanation. The video that works correctly only has sar=16:9 defined; the one that fails, from the newer version of Windows Movie Maker, sets sar=16:9, par=1:1, dar=16:9. Note that ALL these are correct, and the problem is just that Windows DVD Maker under Windows 7 misinterprets the fuller set of aspect ratio parameters, and needs fixing by Microsoft developers. The exact mistake is hard to guess, but the meaning of these parameters is well-understood and the developers at Microsoft who have access to both programs should be able to make Windows DVD Maker understand the output from the newer Windows Live Movie Maker, and other programs which use all these parameters.
    You can work around the problem using various third-party tools which let you edit these parameters, to remove the par and dar values, and then your videos should work correctly in Windows DVD Maker.
    I am rather hoping that, with this information, someone at Microsoft can find and fix the bug. For now, we will have to edit our videos before using them in Windows DVD Maker, or just use the older (2011) version of Windows Live Movie Maker to get videos that work properly.
    As a footnote: a Windows 8.1 version of Windows DVD Maker would be good, too, now that the problem that has been making it less than ideal is clear. Having to run it only under Windows 7 is a real nuisance, as I only have a relatively slow laptop with Windows 7.
    2014-06-16T18:51:51+00:00
    Your response was interesting although my original thread came to the same conclusion i.e. sticking with the older version of WMM, 2011, does resolve the problem. Incidentally I still use, on the odd occasion, Version 2.6 (XP version which runs fine on Windows 7) to use the ability to overlay videos - great for fading out/in between 2 videos. The question still remains "Why does Microsoft NOT fix the problem" !!
