Distorted crackling sound when using either 32/64 bit of Windows 7 on Fujitsu Siemens Esprimo V5535 using High Definition Audio Device.
2010-01-18T08:02:56+00:00
Hi there. I have a problem with sound on my computer. I believe its possibly a bug in Windows 7. Every time I try to play music or watch a video there is some distorted crackling sounds that also come with the audio. I didn't have this problem in XP or Vista. I have tried everything to resolve this problem from reinstalling the sound drivers to changing them to different ones and actually trying different versions of Windows 7 but to no avail. I had no problems with it using the Windows 7 Beta but I do now running the 7600 version. And my lapyop is well capable of running Windows 7 - 2.26Ghz CPU, 2GB Ram, 320MB Graphics card - its very fast. Only problem is sound. I have even tried the Realtek sound drivers for it and I get the same problem - and they are the most recent up-to-date ones.
Please help!!!
2010-09-22T11:13:43+00:00
Hi there. I've actually got the problem fixed - that is if you have a RealTek sound card. You need to contact them about the problem and they should give you a diagnostic tool. Run the tool and get the info. Then send it back to RealTek. I had such good customer service from them it was all done within Half an hour!! They sent me an updated version of their driver that was in the beta stage but had the modification Turn Off Pull Mode (if that makes any sense) and it works completely fine!! I've even got new features with it too  - special enhancments that can change the pitch of the audio, Karaoke mode, Environment effects and Equaliser. No crackling or distorted sound whatsoever.
2010-09-24T15:14:36+00:00
Ok everyone. Here is the link they sent me to get the driver files that work. This should sort it all out.
ftp://ftp3.realtek.com.tw/5898_PG281_Win7_TurnOff_PullMode_Upd.zip
The username is enduser and the password is enduser256
Remember - this only works for Realtek AC'97 and Realtek High Definition Audio Sound Cards.
56 additional answers
    2010-10-21T04:56:23+00:00
    Thank you Starling. I have been having this issue of the crackling audio for about two weeks now. This Latency checker is helping a bit, but I am not exactly sure what it is telling me. I notice two things that happen when I disable some of the things in device manager: When I disable my Intel(R) Pro/100 VE Network Connection (Under the Network Adapters), the audio becomes incredibly worse. When I disable the Microsoft 6to4 Adapter #281 (also under the Network adapters) the audio becomes better, but there are still crackles. Does anyone know if this means my modem is causing the problem? When the internet is turned off, the audio is 10x worse.
    2010-11-01T23:38:01+00:00
    @ Trekaniser;
    After installing umpteen versions of RealTeks drivers over the last week, that special driver has done the trick; pristine sound at last.
    Many thanks for taking the time and trouble to post that link! :D
    2010-11-02T01:28:52+00:00
    You're most welcome!!!
