Distorted crackling sound when using either 32/64 bit of Windows 7 on Fujitsu Siemens Esprimo V5535 using High Definition Audio Device.
2010-01-18T08:02:56+00:00
Hi there. I have a problem with sound on my computer. I believe its possibly a bug in Windows 7. Every time I try to play music or watch a video there is some distorted crackling sounds that also come with the audio. I didn't have this problem in XP or Vista. I have tried everything to resolve this problem from reinstalling the sound drivers to changing them to different ones and actually trying different versions of Windows 7 but to no avail. I had no problems with it using the Windows 7 Beta but I do now running the 7600 version. And my lapyop is well capable of running Windows 7 - 2.26Ghz CPU, 2GB Ram, 320MB Graphics card - its very fast. Only problem is sound. I have even tried the Realtek sound drivers for it and I get the same problem - and they are the most recent up-to-date ones.
Please help!!!
2010-09-22T11:13:43+00:00
Hi there. I've actually got the problem fixed - that is if you have a RealTek sound card. You need to contact them about the problem and they should give you a diagnostic tool. Run the tool and get the info. Then send it back to RealTek. I had such good customer service from them it was all done within Half an hour!! They sent me an updated version of their driver that was in the beta stage but had the modification Turn Off Pull Mode (if that makes any sense) and it works completely fine!! I've even got new features with it too  - special enhancments that can change the pitch of the audio, Karaoke mode, Environment effects and Equaliser. No crackling or distorted sound whatsoever.
2010-09-24T15:14:36+00:00
Ok everyone. Here is the link they sent me to get the driver files that work. This should sort it all out.
ftp://ftp3.realtek.com.tw/5898_PG281_Win7_TurnOff_PullMode_Upd.zip
The username is enduser and the password is enduser256
Remember - this only works for Realtek AC'97 and Realtek High Definition Audio Sound Cards.
56 additional answers
    2010-01-19T00:57:37+00:00
    Hi Trekaniser,
    As you have already tried updating the audio drivers, try disabling the audio enhancements and check if that helps.
    1. Open Sound by clicking the Start button, and then clicking Control Panel. In the search box, type sound, and then click Sound.
    2. On the Playback tab, click Speakers, and then click Properties.
    3. Click the Enhancements tab, and then select the Disable all enhancements check box.
    If you don't see an Enhancements tab in the Speakers Properties dialog box, those features are not available for your speakers and this procedure is not applicable to your computer.
    If disabling audio enhancements solves the audio problem you're experiencing, this typically indicates that your audio driver needs to be updated.
    For more information follow the link given below.
    How do I stop my music from skipping or breaking up when I play it?
    http://windows.microsoft.com/en-us/windows7/How-do-I-stop-my-music-from-skipping-or-breaking-up-when-I-play-it
     You may also check the link given below
    Tips for fixing common sound problems
    http://windows.microsoft.com/en-us/windows7/Tips-for-fixing-common-sound-problems
    Amrita M
    2010-02-25T14:04:30+00:00
    I ran soft-ice againts a windows 7 check-build -- there are interupts conflicting which is causing the crackling. Until Microsoft deals with it we are all stuck with the problem -- "Happy sound crackling to all of us!"
    Programmer
    2010-08-17T06:57:27+00:00
    With due respect, you are WRONG!!!  Microsoft keep blaming this on sound card drives.  I have changed sound cards 3 times, and each new company gives me the latest Windows 7 drivers, and it keeps happening.
    I have a brand new Dell computer, I know it is not to blame, it is a top of the line model.
    1. The on-board Realtek has sound problems with Windows 7
    2. My AudioTrak had problems with Windows 7
    3. My new TASCAM usb soundcard has problems with Windows 7.
    When I loaded XP on the machine, the sound problem disappeared.  Vists seemsed fine.  But when I reloaded Windows 7 again, THERE WAS THE SOUND CRACKLING.
    This is a windows 7 issue, so please stop blaming sound-card manufacturers that have supported the windows platform for so long.
    It is about time Microsoft take responsibility for this issue and FIX IT!!!
    Dan
