this is likely something that needs to be fixed by Denon. do they have a support
forum and are other users reporting the same issue?
Barb
MVP - Windows Entertainment and Connected Home
When I move a group of songs to the play area on the right-hand panel and select the "play-to" drop-down item, my DLNA compatible AV controller appears. When I select it, a new window opens, and the first song on the list begins playing on the AV device. Fine.
The problem is that song just keeps repeating. It doesn't matter whether the "repeat" control is turned on or off. I can click on any song in the list and it happily plays that song - over and over and over :-(
If I select a saved playlist from the DLNA client, it plays just fine and doesn't repeat. Unfortunately, I want to control the device from WMP, not from the panel of the DLNA client.
Help appreciated.
Barb
sounds like you will have a substantial set up captures. do you have a sky drive
or other site where you can upload them?
On Wed, 10 Nov 2010 04:50:07 +0000, dbreviu wrote:
> I will continue to run tests when I get the chance throughout the week while running wireshark and post any abnormal behavior.
Barb Bowman
random thought - what are your power management settings on the host PC?
>So far I am up to song 25 with no unexpected behavior, other than issues using the next/previous buttons on the client PC
Barb Bowman
"balanced"...computer sleeps after 30 minutes. Song 7 is about 17 minutes in, at no point did the PC shut off or try to sleep during playback...I *believe* if media player is open it prevents the computer from shutting off hard drives, sleeping, etc...in the past I'll open it up if I'm doing a long running task and don't want the computer to go to sleep :)
