this is likely something that needs to be fixed by Denon. do they have a support
forum and are other users reporting the same issue?
Barb
MVP - Windows Entertainment and Connected Home
When I move a group of songs to the play area on the right-hand panel and select the "play-to" drop-down item, my DLNA compatible AV controller appears. When I select it, a new window opens, and the first song on the list begins playing on the AV device. Fine.
The problem is that song just keeps repeating. It doesn't matter whether the "repeat" control is turned on or off. I can click on any song in the list and it happily plays that song - over and over and over :-(
If I select a saved playlist from the DLNA client, it plays just fine and doesn't repeat. Unfortunately, I want to control the device from WMP, not from the panel of the DLNA client.
Help appreciated.
Barb
are all the files on the local computer on the local hard drive and are they all
the same file format? the reason I ask is info I found at
http://gcoupe.wordpress.com/2009/05/14/fun-with-technology-%e2%80%93-part-iv/
also, what happens if you select an entire ripped ALBUM in Windows Explorer (not
WMP), right click and select Play To?
On Fri, 15 Oct 2010 11:46:03 +0000, Tabarino wrote:
>Denon AVR-3808CI
>Thanks.
Barb Bowman
Denon AVR-3808CI
Thanks.
what IS the exact device you are using as the client?
>Help appreciated.
Barb Bowman
