Vista/No Sound/Failed to play test tone
2007-04-29T20:12:20+00:00
i have recently upgraded to vista and found out that i have no sound. the driver (vista version) for my on board sound card seems fine but when i try to play a song on windows Media Player, i get a msg of  "Windows Media Player encountered a problem while playing the file. For additional assistance, click Web Help."  and i also get a "Failed to play test tone" msg when i try to test my speakers. i thought it was because of vista dosent support my crappy on board sound card so i got a new one.
i have just installed a Creative Audigy SE and have downloaded the driver for windows vista. again, in device manager, everything seems fine, the driver is fine, the device is working. but i still get the "Windows Media Player encountered a problem while playing the file. For additional assistance, click Web Help." when i try to play a song, as well as the "failed to play test tone" msg when i click on the Test button. please help me, i am tired of using a computer with no sound.
2007-06-28T18:08:17+00:00
This forum probably isn't going to be so helpful with the no-sound issues.  My usual suggestions are to fiddle with drivers and so forth, but I think you're way beyond that.  You might want to try the pro audio forum (http://forums.microsoft.com/MSDN/ShowForum.aspx?ForumID=351&SiteID=1), even though that technically isn't the right place for audio support issues either...
51 additional answers
    2008-09-14T05:49:27+00:00
    garyd11 wrote:
    I had the exact same problem and here is the fix.  You're not going to believe it!<br><br><br> <br><br><br>1 Go to control panel<br><br><br>2. Double-Click on the Sound Icon<br><br><br>3. Single-click the Speakers to highlight them<br><br><br>4. Click on Properties (bottom right corner)<br><br><br>5. Go to the Enhancements Tab and Click on it<br><br><br>6. Now click "Disable All Sound Effects"<br><br><br>7. Click OK and you should be good to go!<br><br><br> <br><br><br>Good luck! <br> ---
    I had to join this forum just to thank this guy, because this solution actually works. I have no idea how you figured it out, but you are amazing! Thank you so much *____*;;
    2008-09-18T14:59:57+00:00
    I was having the same issue.  I tried the above solution, and that didn't work either.  I searched all over the place for an answer.  I was about ready to give up when I stumbled across a thread that said to delete a registry key to fix the issue.  I'm usually pretty hesitant to screw around in the registry, but my next option was a restore to my previous backup. (Ugh!)  So I tried it.  It worked for me!  I am happily jammin' to my tunes!  If all else fails, try this.  Delete this key from your registry: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Ole\DefaultAccessPermission
    Let me know how this works for you.  If it helps, spread the word.  A lot of people are experiancing this problem.
    Lurmis
    2008-09-26T16:50:46+00:00
    Lurmis wrote:
    I was having the same issue.  I tried the above solution, and that didn't work either.  I searched all over the place for an answer.  I was about ready to give up when I stumbled across a thread that said to delete<br> a registry key to fix the issue.  I'm usually pretty hesitant to screw around in the registry, but my next option was a restore to my previous backup. (Ugh!)  So I tried it.  It worked for me!  I am happily jammin' to my tunes!  If all else fails, try this. <br> Delete this key from your registry: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Ole\DefaultAccessPermission<br><br><br> <br><br><br>Let me know how this works for you.  If it helps, spread the word.  A lot of people are experiancing this problem.<br><br><br> <br><br><br>Lurmis <br> ---
    Yeah, that solution doesn't work for me now. I've tried what you suggested and I find no "DefaultAccessPermission" file, I see a "DefaultLaunchPermission", but that's it.
    I'm about to reinstall drivers now to see if that works.. but someone please help me ._.;;
