This forum probably isn't going to be so helpful with the no-sound issues. My usual suggestions are to fiddle with drivers and so forth, but I think you're way beyond that. You might want to try the pro audio forum (http://forums.microsoft.com/MSDN/ShowForum.aspx?ForumID=351&SiteID=1), even though that technically isn't the right place for audio support issues either...
Vista/No Sound/Failed to play test tone
i have recently upgraded to vista and found out that i have no sound. the driver (vista version) for my on board sound card seems fine but when i try to play a song on windows Media Player, i get a msg of "Windows Media Player encountered a problem while playing the file. For additional assistance, click Web Help." and i also get a "Failed to play test tone" msg when i try to test my speakers. i thought it was because of vista dosent support my crappy on board sound card so i got a new one.
i have just installed a Creative Audigy SE and have downloaded the driver for windows vista. again, in device manager, everything seems fine, the driver is fine, the device is working. but i still get the "Windows Media Player encountered a problem while playing the file. For additional assistance, click Web Help." when i try to play a song, as well as the "failed to play test tone" msg when i click on the Test button. please help me, i am tired of using a computer with no sound.
the solution is at the end of this thread:
http://forums.microsoft.com/MSDN/ShowPost.aspx?PostID=2155198&SiteID=1
basically, vista is...
51 additional answers
2007-11-12T13:36:48+00:00 Hey man, your best best is to do a system restore to before you installed aim6 and start using trillian. I tried so many things to recover from the issue that AIM caused. The only working solution for me was to restore back to a few days earlier.
Try the system restore, and if it works, just stay away from AIM forever. Trillian will allow you to use your same name and contact list, so it will be transparent to your friends, but it will work 1000% better. aim tries waaay to hard to tie into ever bit of your system instead of just being the IM program it was created to be. They will never learn though.
2007-12-04T06:23:18+00:00 I had the exact same problem and here is the fix. You're not going to believe it!
1 Go to control panel
- Double-Click on the Sound Icon
- Single-click the Speakers to highlight them
- Click on Properties (bottom right corner)
- Go to the Enhancements Tab and Click on it
- Now click "Disable All Sound Effects"
- Click OK and you should be good to go!
Good luck!
2007-12-16T15:05:55+00:00 I don't know how you figured that out, but THANKS! That solved my problem.
