I click "Address a problem with NVIDIA graphics driver" and it says "This solution could not be downloaded".
2009-12-14T04:08:32+00:00
I click on solve PC issues (the flag) and it says Address a problem with NVIDIA graphics driver. I click it and it says
Most likely causes:
Your computer was unable to download the solution at this time. Check to make sure your computer is connected to the Internet, and then try to download the solution again later.
I am connected to the internet, and windows update works, web browsing works etc. Why isn't it downloading the solution?
2009-12-14T07:50:49+00:00
Download and install the latest nVidia driver for your graphics card.
71 additional answers
    2010-05-12T13:33:20+00:00
    Same as above...
    I have updated to latest driver as of today 5/11/2070 12:55PM EST
    PLEASE someone anyone for the love of god help us...
    Wow, you installed it and you traveled to the future! Kidding aside, I am having the same issue, why can't the solution be downloaded?
    2010-05-11T17:04:24+00:00
    Same as above...
    PLEASE someone anyone for the love of god help us....
    https://cid-4461d172c6f8956d.skydrive.live.com/browse.aspx/errors?uc=5&nl=1
    System Information
    Time of this report: 5/11/2010, 12:47:56
           Machine name: GAMER-PC
       Operating System: Windows 7 Ultimate 64-bit (6.1, Build 7600) (7600.win7_gdr.100226-1909)
               Language: English (Regional Setting: English)
    System Manufacturer: Gateway
           System Model: FX4710-UB802A
                   BIOS: Phoenix - AwardBIOS v6.00PG
              Processor: Intel(R) Core(TM)2 Quad  CPU   Q9300  @ 2.50GHz (4 CPUs), ~2.5GHz
                 Memory: 4096MB RAM
    Available OS Memory: 4094MB RAM
              Page File: 1767MB used, 6418MB available
            Windows Dir: C:\Windows
        DirectX Version: DirectX 11
    DX Setup Parameters: Not found
       User DPI Setting: 96 DPI (100 percent)
     System DPI Setting: 96 DPI (100 percent)
        DWM DPI Scaling: Disabled
         DxDiag Version: 6.01.7600.16385 64bit Unicode
    DxDiag Notes
          Display Tab 1: No problems found.
          Display Tab 2: No problems found.
            Sound Tab 1: No problems found.
            Sound Tab 2: No problems found.
              Input Tab: No problems found.
    DirectX Debug Levels
    Direct3D:    0/4 (retail)
    DirectDraw:  0/4 (retail)
    DirectInput: 0/5 (retail)
    DirectMusic: 0/5 (retail)
    DirectPlay:  0/9 (retail)
    DirectSound: 0/5 (retail)
    DirectShow:  0/6 (retail)
    Display Devices
              Card name: NVIDIA GeForce 9800 GT
           Manufacturer: NVIDIA
              Chip type: GeForce 9800 GT
               DAC type: Integrated RAMDAC
             Device Key: Enum\PCI\VEN_10DE&DEV_0614&SUBSYS_9210174B&REV_A2
         Display Memory: 2286 MB
       Dedicated Memory: 495 MB
          Shared Memory: 1791 MB
           Current Mode: 1920 x 1080 (32 bit) (60Hz)
           Monitor Name: Gateway FHX2300
          Monitor Model: FHX2300
             Monitor Id: GWY00BF
            Native Mode: 1920 x 1080(p) (60.000Hz)
            Output Type: DVI
            Driver Name: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
    Driver File Version: 8.17.0011.9745 (English)
         Driver Version: 8.17.11.9745
            DDI Version: 10
           Driver Model: WDDM 1.1
      Driver Attributes: Final Retail
       Driver Date/Size: 4/3/2010 22:55:32, 11906664 bytes
            WHQL Logo'd: Yes
        WHQL Date Stamp:
      Device Identifier: {D7B71E3E-4554-11CF-EA52-1BB21CC2C535}
              Vendor ID: 0x10DE
              Device ID: 0x0614
              SubSys ID: 0x9210174B
            Revision ID: 0x00A2
     Driver Strong Name: oem17.inf:NVIDIA_SetA_Devices.NTamd64.6.1:Section003:8.17.11.9745:pci\ven_10de&dev_0614
         Rank Of Driver: 00E62001
            Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_C ModeWMV9_C
       Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                         {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                         {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                         {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                         {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                         {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                         {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                         {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                         {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                         {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
           D3D9 Overlay: Supported
                DXVA-HD: Supported
           DDraw Status: Enabled
             D3D Status: Enabled
             AGP Status: Enabled
           Current Mode: 1280 x 1024 (32 bit) (60Hz)
           Monitor Name: Generic PnP Monitor
          Monitor Model: SyncMaster
             Monitor Id: SAM0194
            Native Mode: 1280 x 1024(p) (60.020Hz)
            Output Type: DVI
            DDI Version: 10
            WHQL Logo'd: Yes
        WHQL Date Stamp:
              Vendor ID: 0x10DE
              Device ID: 0x0614
            Revision ID: 0x00A2
                DXVA-HD: Supported
             D3D Status: Enabled
             AGP Status: Enabled
    Sound Devices
                Description: Speakers (High Definition Audio Device)
     Default Sound Playback: Yes
     Default Voice Playback: Yes
                Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0888&SUBSYS_1631E037&REV_1000
            Manufacturer ID: 1
                 Product ID: 65535
                       Type: WDM
                Driver Name: HdAudio.sys
             Driver Version: 6.01.7600.16385 (English)
                WHQL Logo'd: Yes
              Date and Size: 7/13/2009 20:07:00, 350208 bytes
                Other Files:
            Driver Provider: Microsoft
             HW Accel Level: Basic
                  Cap Flags: 0xF1F
        Min/Max Sample Rate: 100, 200000
    Static/Strm HW Mix Bufs: 1, 0
     Static/Strm HW 3D Bufs: 0, 0
                  HW Memory: 0
           Voice Management: No
     EAX(tm) 2.0 Listen/Src: No, No
       I3DL2(tm) Listen/Src: No, No
    Sensaura(tm) ZoomFX(tm): No
    Description: Digital Audio (S/PDIF) (High Definition Audio Device)
     Default Sound Playback: No
     Default Voice Playback: No
            Manufacturer ID: 1
                 Product ID: 65535
                       Type: WDM
                WHQL Logo'd: Yes
                Other Files:
                  Cap Flags: 0xF1F
                  HW Memory: 0
    Sound Capture Devices
                Description: Microphone (High Definition Audio Device)
      Default Sound Capture: Yes
      Default Voice Capture: Yes
                  Cap Flags: 0x1
               Format Flags: 0xFFFFF
    DirectInput Devices
          Device Name: Mouse
             Attached: 1
        Controller ID: n/a
    Vendor/Product ID: n/a
            FF Driver
     Device Name: Keyboard
             Attached: 1
        Controller ID: n/a
            FF Driver: n/a
          Device Name: Microsoft eHome Infrared Transceiver
             Attached: 1
        Controller ID: 0x0
    Vendor/Product ID: 0x045E, 0x006D
            FF Driver: n/a
             Attached: 1
        Controller ID: 0x0
            FF Driver: n/a
             Attached: 1
        Controller ID: 0x0
            FF Driver: n/a
             Attached: 1
        Controller ID: 0x0
            FF Driver: n/a
          Device Name: USB Gaming Mouse
             Attached: 1
        Controller ID: 0x0
    Vendor/Product ID: 0x046D, 0xC041
            FF Driver: n/a
             Attached: 1
        Controller ID: 0x0
            FF Driver: n/a
          Device Name: Logitech Gaming Keyboard
             Attached: 1
        Controller ID: 0x0
    Vendor/Product ID: 0x046D, 0xC221
            FF Driver: n/a
             Attached: 1
        Controller ID: 0x0
            FF Driver: n/a
          Device Name: G15 Keyboard
             Attached: 1
        Controller ID: 0x0
    Vendor/Product ID: 0x046D, 0xC222
            FF Driver: n/a
          Device Name: Nostromo n52 Speedpad2
             Attached: 1
        Controller ID: 0x0
    Vendor/Product ID: 0x050D, 0x0815
            FF Driver: n/a
          Device Name: USB2.0-CRW
             Attached: 1
        Controller ID: 0x0
    Vendor/Product ID: 0x0A48, 0x3302
            FF Driver: n/a
    Poll w/ Interrupt: No
    USB Devices
    • USB Root Hub
    | Vendor/Product ID: 0x8086, 0x2939
    | Matching Device ID: usb\root_hub
    | Service: usbhub
    | Driver: usbhub.sys, 7/13/2009 20:07:09, 343040 bytes
    | Driver: usbd.sys, 7/13/2009 20:06:23, 7936 bytes
    Gameport Devices
    PS/2 Devices
    • Microsoft eHome Remote Control Keyboard keys
    | Matching Device ID: hid\irdevicev2&col05
    | Service: kbdhid
    | Driver: kbdhid.sys, 7/13/2009 20:00:20, 33280 bytes
    | Driver: kbdclass.sys, 7/13/2009 21:48:04, 50768 bytes
    • Microsoft eHome MCIR Keyboard
    | Matching Device ID: hid\irdevicev2&col06
    | Service: kbdhid
    • Microsoft eHome MCIR 109 Keyboard
    | Matching Device ID: hid\irdevicev2&col07
    | Service: kbdhid
    • HID Keyboard Device
    | Matching Device ID: hid_device_system_keyboard
    | Service: kbdhid
    | Service: kbdhid
    | Vendor/Product ID: 0x046D, 0xC232
    | Service: kbdhid
    | Service: kbdhid
    | OEMData: 03 00 88 11 18 00 00 00
    | Flags 1: 04000000
    • Terminal Server Keyboard Driver
    | Matching Device ID: root\rdp_kbd
    | Upper Filters: kbdclass
    | Service: TermDD
    | Driver: i8042prt.sys, 7/13/2009 19:19:57, 105472 bytes
    • HID-compliant mouse
    | Matching Device ID: hid_device_system_mouse
    | Service: mouhid
    | Driver: mouhid.sys, 7/13/2009 20:00:20, 31232 bytes
    | Driver: mouclass.sys, 7/13/2009 21:48:27, 49216 bytes
    | Service: mouhid
    | Vendor/Product ID: 0x046D, 0xC231
    | Service: mouhid
    | Service: mouhid
    | Flags 1: 04000000
    | Service: mouhid
    | Flags 1: 04000000
    • Terminal Server Mouse Driver
    | Matching Device ID: root\rdp_mou
    | Upper Filters: mouclass
    | Service: TermDD
    | Driver: termdd.sys, 7/13/2009 21:45:55, 62544 bytes
    | Driver: sermouse.sys, 7/13/2009 20:00:20, 26624 bytes
    Disk & DVD/CD-ROM Drives
          Drive: C:
     Free Space: 420.5 GB
    Total Space: 564.5 GB
    File System: NTFS
          Model: WDC WD6400AAKS-22A7B0 ATA Device
          Drive: D:
     Free Space: 8.2 GB
    Total Space: 15.9 GB
    File System: NTFS
          Drive: F:
     Free Space: 6.8 GB
    Total Space: 30.0 GB
    File System: NTFS
          Drive: K:
          Model: BUHS TA78DY7GX SCSI CdRom Device
         Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7600.16385 (English), 7/13/2009 19:19:54, 147456 bytes
          Drive: E:
          Model: Optiarc DVD RW AD-7203S ATA Device
    System Devices
         Name: Intel(R) ICH9 Family USB Universal Host Controller - 2935
    Device ID: PCI\VEN_8086&DEV_2935&SUBSYS_E0371631&REV_02\3&2411E6FE&1&E9
       Driver: C:\Windows\system32\drivers\usbuhci.sys, 6.01.7600.16385 (English), 7/13/2009 20:06:27, 30720 bytes
       Driver: C:\Windows\system32\drivers\usbport.sys, 6.01.7600.16385 (English), 7/13/2009 20:06:31, 324608 bytes
       Driver: C:\Windows\system32\drivers\usbhub.sys, 6.01.7600.16385 (English), 7/13/2009 20:07:09, 343040 bytes
         Name: PCI Soft Data Fax Modem with SmartCP
    Device ID: PCI\VEN_14F1&DEV_2F40&SUBSYS_200014F1&REV_00\4&33B27818&0&00F0
       Driver: C:\Windows\SYSTEM32\DRIVERS\CAX_CNXT.sys, 7.67.0000.0000 (English), 6/20/2007 04:29:14, 740352 bytes
       Driver: C:\Windows\SYSTEM32\DRIVERS\CAXHWBS2.sys, 7.67.0000.0000 (English), 6/20/2007 04:30:22, 409600 bytes
       Driver: C:\Windows\SYSTEM32\DRIVERS\CAX_DPV.sys, 7.67.0000.0000 (English), 6/20/2007 04:32:58, 1478656 bytes
       Driver: C:\Windows\SYSTEM32\DRIVERS\HSFProf.cty, 6/30/2007 14:38:38, 143829 bytes
       Driver: C:\Windows\SYSTEM32\DRIVERS\mdmxsdk.sys, 1.00.0002.0012 (English), 6/19/2006 06:27:24, 17024 bytes
       Driver: C:\Windows\SYSTEM32\DRIVERS\XAudio64.sys, 1.00.0011.0000 (English), 6/29/2007 09:11:24, 10240 bytes
       Driver: C:\Windows\SYSTEM32\DRIVERS\XAudio64.exe, 1.00.0011.0000 (English), 6/29/2007 09:11:36, 412672 bytes
       Driver: C:\Windows\SysWOW64\mdmxsdk.dll, 1.00.0002.0012 (English), 6/19/2006 06:26:50, 94208 bytes
       Driver: C:\Program Files\CONEXANT\CNXT_MODEM_PCI_HSF\UIU64m.exe, 4.00.0026.0000 (English), 6/26/2007 04:24:40, 1066496 bytes
       Driver: C:\Windows\system32\UCI64M20.dll, 2.00.0020.0000 (English), 7/13/2007 04:43:36, 310272 bytes
         Name: High Definition Audio Controller
    Device ID: PCI\VEN_8086&DEV_293E&SUBSYS_E0371631&REV_02\3&2411E6FE&1&D8
       Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 6.01.7600.16385 (English), 7/13/2009 20:06:13, 122368 bytes
         Name: Intel(R) ICH9 Family USB Universal Host Controller - 2934
    Device ID: PCI\VEN_8086&DEV_2934&SUBSYS_E0371631&REV_02\3&2411E6FE&1&E8
         Name: ABY8NVP9 IDE Controller
    Device ID: PCI\VEN_11AB&DEV_6122&SUBSYS_BDD19BA9&REV_01\4&5D18F2DF&0
       Driver: n/a
         Name: Intel(R) ICH9 Family USB2 Enhanced Host Controller - 293C
    Device ID: PCI\VEN_8086&DEV_293C&SUBSYS_E0371631&REV_02\3&2411E6FE&1&D7
       Driver: C:\Windows\system32\drivers\usbehci.sys, 6.01.7600.16385 (English), 7/13/2009 20:06:30, 51200 bytes
         Name: Intel(R) ICH9 Family SMBus Controller - 2930
    Device ID: PCI\VEN_8086&DEV_2930&SUBSYS_E0371631&REV_02\3&2411E6FE&1&FB
       Driver: n/a
         Name: VIA 1394 OHCI Compliant Host Controller
    Device ID: PCI\VEN_1106&DEV_3044&SUBSYS_E0371631&REV_C0\4&33B27818&0&30F0
       Driver: C:\Windows\system32\DRIVERS\1394ohci.sys, 6.01.7600.16385 (English), 7/13/2009 20:07:13, 227840 bytes
         Name: Intel(R) ICH9 Family USB2 Enhanced Host Controller - 293A
    Device ID: PCI\VEN_8086&DEV_293A&SUBSYS_E0371631&REV_02\3&2411E6FE&1&EF
         Name: Standard Dual Channel PCI IDE Controller
    Device ID: PCI\VEN_8086&DEV_2926&SUBSYS_E0371631&REV_02\3&2411E6FE&1&FD
       Driver: C:\Windows\system32\DRIVERS\pciide.sys, 6.01.7600.16385 (English), 7/13/2009 21:45:45, 12352 bytes
       Driver: C:\Windows\system32\DRIVERS\pciidex.sys, 6.01.7600.16385 (English), 7/13/2009 21:45:46, 48720 bytes
       Driver: C:\Windows\system32\DRIVERS\atapi.sys, 6.01.7600.16385 (English), 7/13/2009 21:52:21, 24128 bytes
       Driver: C:\Windows\system32\DRIVERS\ataport.sys, 6.01.7600.16385 (English), 7/13/2009 21:52:21, 155728 bytes
         Name: NVIDIA GeForce 9800 GT
    Device ID: PCI\VEN_10DE&DEV_0614&SUBSYS_9210174B&REV_A2\4&33F361A3&0&0008
       Driver: C:\Windows\System32\DriverStore\FileRepository\nv_disp.inf_amd64_neutral_9a742a8aa1c06321\NvCplSetupEng.exe, 14.00.0000.0162 (English), 4/3/2010 18:55:31, 19067128 bytes
       Driver: C:\Windows\system32\DRIVERS\nvBridge.kmd, 8.17.0011.9745 (English), 4/3/2010 22:55:32, 11240 bytes
       Driver: C:\Windows\system32\DRIVERS\nvlddmkm.sys, 8.17.0011.9745 (English), 4/3/2010 22:55:32, 13807976 bytes
       Driver: C:\Windows\system32\OpenCL.dll, 1.00.0000.0000
    2010-05-05T22:04:21+00:00
    Hi umm im having this problem too along with the nvldmkm.sys problem that ends up as the BSOD i have the latest driver installed and still having issues every time i turn my pc on
    Here is a copy of my system info
    System Information
    Time of this report: 5/5/2010, 15:00:07
           Machine name: AMEZCUA-PC
       Operating System: Windows 7 Ultimate 32-bit (6.1, Build 7600) (7600.win7_gdr.100226-1909)
           System Model: DX420X
                   BIOS: Default System BIOS
              Processor: Intel(R) Core(TM)2 CPU          6400  @ 2.13GHz (2 CPUs), ~2.1GHz
                 Memory: 2048MB RAM
    Available OS Memory: 2030MB RAM
              Page File: 494MB used, 3564MB available
         DxDiag Version: 6.01.7600.16385 32bit Unicode
    DxDiag Notes
            Sound Tab 1: This computer cannot play audio because the Windows Audio service is not enabled.  Use the Sounds and Devices Properties control panel to enable audio. No sound card was found.  If one is expected, you should install a sound driver provided by the hardware manufacturer.
    Display Devices
              Card name:
           Manufacturer:
              Chip type:
               DAC type:
             Device Key: Enum\
         Display Memory: n/a
       Dedicated Memory: n/a
          Shared Memory: n/a
           Current Mode: 1280 x 1024 (32 bit) (1Hz)
            Driver Name:
    Driver File Version:  ()
         Driver Version:
            DDI Version: unknown
           Driver Model: unknown
       Driver Date/Size: , 0 bytes
            WHQL Logo'd: n/a
        WHQL Date Stamp: n/a
      Device Identifier: {D7B70EE0-4340-11CF-B123-B03DAEC2CB35}
              Vendor ID: 0x0000
              Device ID: 0x0000
              SubSys ID: 0x00000000
            Revision ID: 0x0000
     Driver Strong Name: Unknown
         Rank Of Driver: Unknown
            Video Accel:
          Deinterlace Caps: n/a
           D3D9 Overlay: n/a
                DXVA-HD: n/a
           DDraw Status: Not Available
             D3D Status: Not Available
             AGP Status: Not Available
    Sound Devices
                Description:
                Hardware ID:
            Manufacturer ID:
                 Product ID:
                       Type:
                Driver Name:
             Driver Version:
          Driver Attributes:
                WHQL Logo'd:
              Date and Size:
                Other Files:
            Driver Provider:
             HW Accel Level: Emulation Only
                  Cap Flags: 0x0
        Min/Max Sample Rate: 0, 0
    Static/Strm HW Mix Bufs: 0, 0
                  HW Memory: 0
    DirectInput Devices
          Device Name: Mouse
             Attached: 1
        Controller ID: n/a
            FF Driver: n/a
             Attached: 1
        Controller ID: n/a
            FF Driver: n/a
          Device Name: Microsoft Hardware wireless mouse driver
             Attached: 1
        Controller ID: 0x0
    Vendor/Product ID: 0x045E, 0x00E1
            FF Driver: n/a
    USB Devices
    • USB Root Hub
    | Vendor/Product ID: 0x8086, 0x2834
    | Service: usbhub
    | Driver: usbhub.sys, 7/13/2009 16:52:09, 258560 bytes
    | Driver: usbd.sys, 7/13/2009 16:51:05, 5888 bytes
    Gameport Devices
    PS/2 Devices
    • Standard PS/2 Keyboard
    | Matching Device ID: *pnp0303
    | Service: i8042prt
    | Driver: i8042prt.sys, 7/13/2009 16:11:24, 80896 bytes
    | Driver: kbdclass.sys, 7/13/2009 18:20:36, 42576 bytes
    | Service: TermDD
    • Microsoft USB Wireless Mouse (IntelliPoint)
    | Matching Device ID: hid\vid_045e&pid_00e1&col02
    | Upper Filters: Point32
    | Service: mouhid
    | Driver: point32k.sys, 6/1/2009 14:51:54, 30088 bytes
    | Driver: mouhid.sys, 7/13/2009 16:45:08, 26112 bytes
    | Driver: mouclass.sys, 7/13/2009 18:20:44, 41552 bytes
    | Service: TermDD
    | Driver: termdd.sys, 7/13/2009 18:19:10, 51776 bytes
    | Driver: sermouse.sys, 7/13/2009 16:45:08, 19968 bytes
          Drive: C:
     Free Space: 60.3 GB
    Total Space: 300.2 GB
    File System: NTFS
          Model: WDC WD3200JS-22PDB0
          Drive: D:
     Free Space: 1.8 GB
    Total Space: 5.0 GB
    File System: FAT32
          Drive: E:
          Model: ATAPI DVD W  DH16W1P ATA Device
         Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7600.16385 (English), 7/13/2009 16:11:26, 108544 bytes
          Drive: F:
          Model: LITE-ON COMBO SOHC-4836V ATA Device
    System Devices
         Name: Intel(R) ICH8 Family PCI Express Root Port 2 - 2841
    Device ID: PCI\VEN_8086&DEV_2841&SUBSYS_28418086&REV_02\3&18D45AA6&0&E1
       Driver: C:\Windows\system32\DRIVERS\pci.sys, 6.01.7600.16385 (English), 7/13/2009 18:20:45, 153680 bytes
         Name: Intel(R) ICH8 Family USB Universal Host Controller - 2831
    Device ID: PCI\VEN_8086&DEV_2831&SUBSYS_505A107B&REV_02\3&18D45AA6&0&E9
       Driver: C:\Windows\system32\drivers\usbuhci.sys, 6.01.7600.16385 (English), 7/13/2009 16:51:10, 24064 bytes
       Driver: C:\Windows\system32\drivers\usbport.sys, 6.01.7600.16385 (English), 7/13/2009 16:51:15, 284160 bytes
       Driver: C:\Windows\system32\drivers\usbhub.sys, 6.01.7600.16385 (English), 7/13/2009 16:52:09, 258560 bytes
         Name: NVIDIA GeForce 7600 GS
    Device ID: PCI\VEN_10DE&DEV_0392&SUBSYS_3A13107B&REV_A1\4&28F84E77&0&0008
       Driver: C:\Windows\System32\DriverStore\FileRepository\nv_disp.inf_x86_neutral_41aad7f8b629e0a1\NvCplSetupEng.exe, 14.00.0000.0162 (English), 11/20/2009 19:34:54, 16933624 bytes
       Driver: C:\Windows\system32\DRIVERS\nvBridge.kmd, 8.17.0011.9562 (English), 11/20/2009 19:34:54, 10920 bytes
       Driver: C:\Windows\system32\DRIVERS\nvlddmkm.sys, 8.17.0011.9562 (English), 11/20/2009 19:34:54, 11515752 bytes
       Driver: C:\Windows\system32\OpenCL.dll, 1.00.0000.0000 (English), 11/20/2009 19:34:54, 76392 bytes
       Driver: C:\Windows\system32\dpinst.exe, 2.01.0000.0000 (English), 9/28/2009 00:12:22, 795104 bytes
       Driver: C:\Windows\system32\nvapi.dll, 8.17.0011.9562 (English), 11/20/2009 19:34:54, 1249896 bytes
       Driver: C:\Windows\system32\nvcompiler.dll, 8.17.0011.9562 (English), 11/20/2009 19:34:54, 11381352 bytes
       Driver: C:\Windows\system32\nvcuda.dll, 8.17.0011.9562 (English), 11/20/2009 19:34:54, 4001384 bytes
       Driver: C:\Windows\system32\nvcuvenc.dll, 8.17.0011.9562 (English), 11/20/2009 19:34:54, 1989224 bytes
       Driver: C:\Windows\system32\nvcuvid.dll, 8.17.0011.9562 (English), 11/20/2009 19:34:54, 2243176 bytes
       Driver: C:\Windows\system32\nvd3dum.dll, 8.17.0011.9562 (English), 11/20/2009 19:34:54, 9333352 bytes
       Driver: C:\Windows\system32\nvinfo.pb, 11/20/2009 19:34:54, 7133 bytes
       Driver: C:\Windows\system32\nvoglv32.dll, 8.17.0011.9562 (English), 11/20/2009 19:34:54, 14064232 bytes
       Driver: C:\Program Files\NVIDIA Corporation\Uninstall\nvdisp.nvu, 11/20/2009 19:34:54, 19077 bytes
       Driver: C:\Program Files\NVIDIA Corporation\Uninstall\nvudisp.exe, 1.10.0052.0030 (English), 11/20/2009 19:34:54, 592488 bytes
       Driver: C:\Windows\system32\nvcod.dll, 1.07.0008.0073 (English), 11/20/2009 19:34:54, 182888 bytes
       Driver: C:\Windows\system32\nvcod178.dll, 1.07.0008.0073 (English), 11/20/2009 19:34:54, 182888 bytes
         Name: PCI Simple Communications Controller
    Device ID: PCI\VEN_8086&DEV_29A4&SUBSYS_505A107B&REV_02\3&18D45AA6&0&18
       Driver: n/a
         Name: Intel(R) ICH8 Family PCI Express Root Port 1 - 283F
    Device ID: PCI\VEN_8086&DEV_283F&SUBSYS_283F8086&REV_02\3&18D45AA6&0&E0
         Name: Intel(R) ICH8 Family USB Universal Host Controller - 2830
    Device ID: PCI\VEN_8086&DEV_2830&SUBSYS_505A107B&REV_02\3&18D45AA6&0&E8
         Name: Texas Instruments 1394 OHCI Compliant Host Controller
    Device ID: PCI\VEN_104C&DEV_8023&SUBSYS_505A107B&REV_00\4&77CEEF&0&18F0
       Driver: C:\Windows\system32\DRIVERS\1394ohci.sys, 6.01.7600.16385 (English), 7/13/2009 16:52:00, 163328 bytes
         Name: Intel(R) P965/G965 PCI Express Root Port - 29A1
    Device ID: PCI\VEN_8086&DEV_29A1&SUBSYS_00008086&REV_02\3&18D45AA6&0&08
         Name: Intel(R) ICH8 Family SMBus Controller - 283E
    Device ID: PCI\VEN_8086&DEV_283E&SUBSYS_505A107B&REV_02\3&18D45AA6&0&FB
       Driver: n/a
         Name: Intel(R) ICH8R/ICH9R/ICH10R/DO SATA RAID Controller
    Device ID: PCI\VEN_8086&DEV_2822&SUBSYS_505A107B&REV_02\3&18D45AA6&0&FA
       Driver: C:\Windows\system32\DRIVERS\iaStorV.sys, 8.06.0002.1012 (English), 7/13/2009 18:20:36, 332352 bytes
         Name: Intel(R) P965/G965 Processor to I/O Controller - 29A0
    Device ID: PCI\VEN_8086&DEV_29A0&SUBSYS_505A107B&REV_02\3&18D45AA6&0&00
       Driver: n/a
         Name: Intel(R) ICH8 Family USB2 Enhanced Host Controller - 283A
    Device ID: PCI\VEN_8086&DEV_283A&SUBSYS_505A107B&REV_02\3&18D45AA6&0&D7
       Driver: C:\Windows\system32\drivers\usbehci.sys, 6.01.7600.16385 (English), 7/13/2009 16:51:14, 41472 bytes
         Name: Intel(R) ICH8DH LPC Interface Controller - 2812
    Device ID: PCI\VEN_8086&DEV_2812&SUBSYS_505A107B&REV_02\3&18D45AA6&0&F8
       Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 6.01.7600.16385 (English), 7/13/2009 18:20:43, 13888 bytes
    Device ID: PCI\VEN_8086&DEV_284B&SUBSYS_6049107B&REV_02\3&18D45AA6&0&D8
       Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 6.01.7600.16385 (English), 7/13/2009 16:50:56, 108544 bytes
         Name: Intel(R) ICH8 Family USB2 Enhanced Host Controller - 2836
    Device ID: PCI\VEN_8086&DEV_2836&SUBSYS_505A107B&REV_02\3&18D45AA6&0&EF
         Name: Intel(R) 82801 PCI Bridge - 244E
    Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_505A107B&REV_F2\3&18D45AA6&0&F0
         Name: Intel(R)  946GZ Express Chipset Family
    Device ID: ROOT\DISPLAY\0000
       Driver: C:\Windows\system32\DRIVERS\igdkmd32.sys, 8.14.0010.1930 (English), 9/23/2009 19:18:14, 4808192 bytes
       Driver: C:\Windows\system32\igdumd32.dll, 8.14.0010.1930 (English), 9/23/2009 19:18:08, 3829760 bytes
       Driver: C:\Windows\system32\igkrng400.bin, 9/23/2009 19:16:08, 2050952 bytes
       Driver: C:\Windows\system32\iglhxs32.vp, 9/23/2009 19:45:20, 39440 bytes
       Driver: C:\Windows\system32\iglhxo32.vp, 9/23/2009 18:45:12, 60015 bytes
       Driver: C:\Windows\system32\iglhxc32.vp, 9/23/2009 18:45:12, 60226 bytes
       Driver: C:\Windows\system32\iglhxg32.vp, 9/23/2009 18:45:12, 60254 bytes
       Driver: C:\Windows\system32\iglhxa32.vp, 9/23/2009 18:45:12, 1090 bytes
       Driver: C:\Windows\system32\iglhxa32.cpa, 9/23/2009 18:45:12, 1921265 bytes
       Driver: C:\Windows\system32\hccutils.dll, 8.14.0010.1930 (English), 9/23/2009 18:49:04, 94208 bytes
       Driver: C:\Windows\system32\igfxsrvc.dll, 8.14.0010.1930 (English), 9/23/2009 18:49:24, 51712 bytes
       Driver: C:\Windows\system32\igfxsrvc.exe, 8.14.0010.1930 (English), 9/23/2009 19:30:48, 252952 bytes
       Driver: C:\Windows\system32\igfxpph.dll, 8.14.0010.1930 (English), 9/23/2009 18:49:42, 199680 bytes
       Driver: C:\Windows\system32\igfxcpl.cpl, 8.14.0010.1930 (English), 9/23/2009 18:49:34, 119296 bytes
       Driver: C:\Windows\system32\igfxcfg.exe, 8.14.0010.1930 (English), 9/23/2009 19:30:50, 672792 bytes
       Driver: C:\Windows\system32\igfxdev.dll, 8.14.0010.1930 (English), 9/23/2009 18:49:00, 218112 bytes
       Driver: C:\Windows\system32\igfxdo.dll, 8.14.0010.1930 (English), 9/23/2009 18:49:10, 130048 bytes
       Driver: C:\Windows\system32\igfxtray.exe, 8.14.0010.1930 (English), 9/23/2009 19:30:48, 141848 bytes
       Driver: C:\Windows\system32\hkcmd.exe, 8.14.0010.1930 (English), 9/23/2009 19:30:48, 173592 bytes
       Driver: C:\Windows\system32\igfxress.dll, 8.14.0010.1930 (English), 9/23/2009 18:48:52, 5702656 bytes
       Driver: C:\Windows\system32\igfxpers.exe, 8.14.0010.1930 (English), 9/23/2009 19:30:48, 150552 bytes
       Driver: C:\Windows\system32\igfxTMM.dll, 8.14.0010.1930 (English), 9/23/2009 18:49:42, 257536 bytes
       Driver: C:\Windows\system32\TVWSetup.exe, 1.00.0001.0000 (English), 9/23/2009 19:30:50, 8198680 bytes
       Driver: C:\Windows\system32\igfxext.exe, 8.14.0010.1930 (English), 9/23/2009 19:30:48, 173080 bytes
       Driver: C:\Windows\system32\igfxexps.dll, 8.14.0010.1930 (English), 9/23/2009 18:49:36, 23552 bytes
       Driver: C:\Windows\system32\oemdspif.dll, 8.14.0010.1930 (English), 9/23/2009 18:49:38, 59392 bytes
       Driver: C:\Windows\system32\igfxrara.lrc, 8.14.0010.1930 (English), 9/23/2009 18:52:08, 252416 bytes
       Driver: C:\Windows\system32\igfxrchs.lrc, 8.14.0010.1930 (English), 9/23/2009 18:52:10, 178176 bytes
       Driver: C:\Windows\system32\igfxrcht.lrc, 8.14.0010.1930 (English), 9/23/2009 18:52:10, 179712 bytes
       Driver: C:\Windows\system32\igfxrdan.lrc, 8.14.0010.1930 (English), 9/23/2009 18:52:10, 280576 bytes
       Driver: C:\Windows\system32\igfxrdeu.lrc, 8.14.0010.1930 (English), 9/23/2009 18:52:10, 303616 bytes
       Driver: C:\Windows\system32\igfxrenu.lrc, 8.14.0010.1930 (English), 9/23/2009 18:48:52, 275968 bytes
       Driver: C:\Windows\system32\igfxresp.lrc, 8.14.0010.1930 (English), 9/23/2009 18:52:12, 303104 bytes
       Driver: C:\Windows\system32\igfxrfin.lrc, 8.14.0010.1930 (English), 9/23/2009 18:52:12, 281088 bytes
       Driver: C:\Windows\system32\igfxrfra.lrc, 8.14.0010.1930 (English), 9/23/2009 18:52:12, 303616 bytes
       Driver: C:\Windows\system32\igfxrheb.lrc, 8.14.0010.1930 (English), 9/23/2009 18:52:14, 249856 bytes
       Driver: C:\Windows\system32\igfxrita.lrc, 8.14.0010.1930 (English), 9/23/2009 18:52:14, 304640 bytes
       Driver: C:\Windows\system32\igfxrjpn.lrc, 8.14.0010.1930 (English), 9/23/2009 18:52:14, 206848 bytes
       Driver: C:\Windows\system32\igfxrkor.lrc, 8.14.0010.1930 (English), 9/23/2009 18:52:14, 205312 bytes
       Driver: C:\Windows\system32\igfxrnld.lrc, 8.14.0010.1930 (English), 9/23/2009 18:52:16, 299520 bytes
       Driver: C:\Windows\system32\igfxrnor.lrc, 8.14.0010.1930 (English), 9/23/2009 18:52:16, 280064 bytes
       Driver: C:\Windows\system32\igfxrplk.lrc, 8.14.0010.1930 (English), 9/23/2009 18:52:16, 287744 bytes
       Driver: C:\Windows\system32\igfxrptb.lrc, 8.14.0010.1930 (English), 9/23/2009 18:52:16, 289280 bytes
       Driver: C:\Windows\system32\igfxrptg.lrc, 8.14.0010.1930 (English), 9/23/2009 18:52:18, 294912 bytes
       Driver: C:\Windows\system32\igfxrrus.lrc, 8.14.0010.1930 (English), 9/23/2009 18:52:18, 291328 bytes
       Driver: C:\Windows\system32\igfxrsky.lrc, 8.14.0010.1930 (English), 9/23/2009 18:52:18, 282624 bytes
       Driver: C:\Windows\system32\igfxrslv.lrc, 8.14.0010.1930 (English), 9/23/2009 18:52:18, 277504 bytes
       Driver: C:\Windows\system32\igfxrsve.lrc, 8.14.0010.1930 (English), 9/23/2009 18:52:18, 282624 bytes
       Driver: C:\Windows\system32\igfxrtha.lrc, 8.14.0010.1930 (English), 9/23/2009 18:52:20, 262656 bytes
       Driver: C:\Windows\system32\igfxrcsy.lrc, 8.14.0010.1930 (English), 9/23/2009 18:52:10, 282624 bytes
       Driver: C:\Windows\system32\igfxrell.lrc, 8.14.0010.1930 (English), 9/23/2009 18:52:12, 310784 bytes
       Driver: C:\Windows\system32\igfxrhun.lrc, 8.14.0010.1930 (English), 9/23/2009 18:52:14, 288256 bytes
       Driver: C:\Windows\system32\igfxrtrk.lrc, 8.14.0010.1930 (English), 9/23/2009 18:52:20, 279040 bytes
       Driver: C:\Windows\system32\ig4icd32.dll, 8.14.0010.1930 (English), 9/23/2009 18:58:12, 4104192 bytes
       Driver: C:\Windows\system32\ig4dev32.dll, 8.14.0010.1930 (English), 9/23/2009 18:58:38, 2686976 bytes
       Driver: C:\Windows\system32\igdumdx32.dll, 8.14.0010.1930 (English), 9/23/2009 19:14:54, 536576 bytes
       Driver: C:\Windows\system32\igfxCoIn_v1930.dll, 1.01.0017.0000 (English), 9/23/2009 19:27:44, 155648 bytes
         Name: Intel(R) ICH8 Family PCI Express Root Port 5 - 2847
    Device ID: PCI\VEN_8086&DEV_2847&SUBSYS_28478086&REV_02\3&18D45AA6&0&E4
         Name: Intel(R) ICH8 Family USB Universal Host Controller - 2835
    Device ID: PCI\VEN_8086&DEV_2835&SUBSYS_505A107B&REV_02\3&18D45AA6&0&D1
         Name: Intel(R) 82562V 10/100 Network Connection
    Device ID: PCI\VEN_8086&DEV_104C&SUBSYS_0001107B&REV_02\3&18D45AA6&0&C8
       Driver: C:\Windows\system32\DRIVERS\e1e6032.sys, 9.13.0004.0010 (English), 7/13/2009 15:02:50, 211456 bytes
         Name: Intel(R) ICH8 Family PCI Express Root Port 4 - 2845
    Device ID: PCI\VEN_8086&DEV_2845&SUBSYS_28458086&REV_02\3&18D45AA6&0&E3
         Name: Intel(R) ICH8 Family USB Universal Host Controller - 2834
    Device ID: PCI\VEN_8086&DEV_2834&SUBSYS_505A107B&REV_02\3&18D45AA6&0&D0
    Device ID: PCI\VEN_14F1&DEV_2F20&SUBSYS_200014F1&REV_00\4&77CEEF&0&08F0
       Driver: C:\Windows\SYSTEM32\DRIVERS\HSX_CNXT.sys, 7.80.0004.0000 (English), 2/13/2009 06:57:28, 661504 bytes
       Driver: C:\Windows\SYSTEM32\DRIVERS\HSXHWBS2.sys, 7.80.0004.0000 (English), 2/13/2009 21:58:30, 266752 bytes
       Driver: C:\Windows\SYSTEM32\DRIVERS\HSX_DPV.sys, 7.80.0004.0000 (English), 2/13/2009 22:00:22, 980992 bytes
       Driver: C:\Windows\SYSTEM32\DRIVERS\HSFProf.cty, 2/13/2009 23:55:32, 146036 bytes
       Driver: C:\Windows\SYSTEM32\DRIVERS\mdmxsdk.sys, 1.00.0002.0012 (English), 6/18/2006 15:26:58, 12672 bytes
       Driver: C:\Windows\SYSTEM32\DRIVERS\XAudio32.sys, 1.00.0023.0000 (English), 4/29/2009 04:20:56, 8704 bytes
       Driver: C:\Windows\system32\mdmxsdk.dll, 1.00.0002.0012 (English), 6/18/2006 15:26:50, 94208 bytes
       Driver: C:\Windows\system32\XAudio32.dll, 1.00.0023.0000 (English), 4/29/2009 04:21:04, 410624 bytes
       Driver: C:\Program Files\CONEXANT\CNXT_MODEM_PCI_HSF\UIU32m.exe, 4.62.0004.0000 (English), 6/18/2009 04:35:32, 1118208 bytes
       Driver: C:\Windows\system32\UCI32M41.dll, 2.00.0041.0000 (English), 5/6/2009 03:57:58, 258048 bytes
         Name: Intel(R) ICH8 Family PCI Express Root Port 3 - 2843
    Device ID: PCI\VEN_8086&DEV_2843&SUBSYS_28438086&REV_02\3&18D45AA6&0&E2
         Name: Intel(R) ICH8 Family USB Universal Host Controller - 2832
    Device ID: PCI\VEN_8086&DEV_2832&SUBSYS_505A107B&REV_02\3&18D45AA6&0&EA
    Device ID: PCI\VEN_11AB&DEV_6101&SUBSYS_610111AB&REV_B1\4&97BC3A7&0&00E1
       Driver: C:\Windows\system32\DRIVERS\pciide.sys, 6.01.7600.16385 (English), 7/13/2009 18:20:45, 12368 bytes
       Driver: C:\Windows\system32\DRIVERS\pciidex.sys, 6.01.7600.16385 (English), 7/13/2009 18:19:03, 42560 bytes
       Driver: C:\Windows\system32\DRIVERS\atapi.sys, 6.01.7600.16385 (English), 7/13/2009 18:26:15, 21584 bytes
       Driver: C:\Windows\system32\DRIVERS\ataport.sys, 6.01.7600.16385 (English), 7/13/2009 18:26:15, 133200 bytes
    DirectShow Filters
    DirectShow Filters:
    QuickTime Audio Decoder Filter,0x00600800,1,1,gzHF330.ddc,1.01.0000.0017
    WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7600.16385
    WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7600.16385
    WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7600.16385
    MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7600.16385
    Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7600.16385
    WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7600.16385
    WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7600.16385
    QuickTime Video Decoder Filter,0x00600800,1,1,mtw178.ddc,1.01.0000.0017
    Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7600.16385
    Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7600.16385
    FunUnify Audio Trnas Filter,0x00200000,1,1,FunCodecFilter.ax,1.00.0000.0001
    WMT VIH2 Fix,0x00200000,1,1,WLXVAFilt.dll,14.00.8081.0709
    Record Queue,0x00200000,1,1,WLXVAFilt.dll,14.00.8081.0709
    WMT Switch Filter,0x00200000,1,1,WLXVAFilt.dll,14.00.8081.0709
    WMT Virtual Renderer,0x00200000,1,0,WLXVAFilt.dll,14.00.8081.0709
    WMT DV Extract,0x00200000,1,1,WLXVAFilt.dll,14.00.8081.0709
    WMT Virtual Source,0x00200000,0,1,WLXVAFilt.dll,14.00.8081.0709
    WMT Sample Information Filter,0x00200000,1,1,WLXVAFilt.dll,14.00.8081.0709
    DV Muxer,0x00400000,0,0,qdv.dll,6.06.7600.16385
    Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7600.16490
    WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7600.16385
    DivX AAC Decoder,0x00800000,1,1,daac.ax,7.01.0000.0010
    Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7600.16385
    AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7600.16490
    VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7600.16490
    SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7600.16385
    FunUnify Async Filter,0x00600000,0,0,FunCodecFilter.ax,1.00.0000.0001
    Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,6.01.7140.0000
    AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7600.16385
    StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7600.16385
    Microsoft TV Captions Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7600.16385
    MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7600.16490
    CBVA DMO wrapper filter,0x00200000,1,1,cbva.dll,6.01.7600.16385
    MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7600.16490
    SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7600.16490
    VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7600.16385
    MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7600.16385
    Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7600.16385
    SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7600.16385
    Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7600.16385
    Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7600.16490
    MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7600.16490
    DV Splitter,0x00600000,1,2,qdv.dll,6.06.7600.16385
    Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,3.00.0000.3433
    Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7600.16490
    Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.0340
    FunBox Avi Splitter,0x00600000,1,1,FunAviSplitter.ax,
    Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7600.16385
    ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7600.16490
    Video Renderer,0x00800001,1,0,quartz.dll,6.06.7600.16490
    MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7600.16385
    FunUnify Codec Filter,0x00600000,0,0,FunCodecFilter.ax,1.00.0000.0001
    Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.06.7600.16385
    Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7600.16490
    DivX H.264 Decoder,0x00800000,1,1,DivXDecH264.ax,8.02.0000.0026
    Video Renderer,0x00400000,1,0,quartz.dll,6.06.7600.16490
    File Writer,0x00200000,1,0,WLXVAFilt.dll,14.00.8081.0709
    DivX Decoder Filter,0x00800000,1,1,divxdec.ax,7.00.0000.0031
    FunBox Avi Source,0x00600000,0,0,FunAviSplitter.ax,
    VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7600.16385
    WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7600.16385
    VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7600.16385
    File writer,0x00200000,1,0,qcap.dll,6.06.7600.16385
    iTV Data Sink,0x00600000,1,0,itvdata.dll,6.06.7600.16385
    iTV Data Capture filter,0x00600000,1,1,itvdata.dll,6.06.7600.16385
    DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7600.16385
    Microsoft TV Subtitles Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7600.16385
    Overlay Mixer2,0x00200000,1,1,qdvd.dll,6.06.7600.16385
    DivX MKV Demux,0x00200000,0,1,DMFSource.ax,1.00.0001.0004
    AVI Draw,0x00600064,9,1,quartz.dll,6.06.7600.16490
    RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll,
    Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7600.16385
    WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7600.16385
    MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7600.16385
    DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7600.16385
    FunUnify Encoder Filter,0x00200000,0,0,FunCodecFilter.ax,1.00.0000.0001
    FunUnify Video Trans Filter,0x00200000,1,1,FunCodecFilter.ax,1.00.0000.0001
    SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7600.16385
    Null Renderer,0x00200000,1,0,qedit.dll,6.06.7600.16385
    MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7600.16385
    Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7600.16385
    StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.7600.16385
    Smart Tee,0x00200000,1,2,qcap.dll,6.06.7600.16385
    Overlay Mixer,0x00200000,0,0,qdvd.dll,6.06.7600.16385
    AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7600.16490
    NetBridge,0x00200000,2,0,netbridge.dll,6.01.7600.16385
    KTF MUSIC VoD Sourcer,0x00200000,0,1,npsvsrc.dll,1.00.0008.0708
    SubPicture Filter,0x00200000,0,1,NPSSubPicture.dll,1.00.0000.0001
    AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7600.16490
    KTF MUSIC Audio Effector,0x00200000,1,1,npsaef.dll,1.01.0008.0708
    Wave Parser,0x00400000,1,1,quartz.dll,6.06.7600.16490
    MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7600.16490
    Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7600.16490
    File stream renderer,0x00400000,1,1,quartz.dll,6.06.7600.16490
    KTF MUSIC VoD WMT Splitter,0x00200000,1,1,npsvwms.dll,1.01.0008.0708
    KTF MUSIC MPEG Splitter,0x00200000,0,1,npsmpgs.dll,1.00.0008.0708
    KTF MUSIC Audio Decoder,0x00200000,1,1,npsadec.dll,1.00.0008.0708
    KTF MUSIC AoD Sourcer,0x00600000,0,1,npsasrc.dll,1.00.0008.0708
    KTF MUSIC VoD Video Effector,0x00200000,1,1,npsvve.dll,1.00.0008.0708
    KTF MUSIC AoD WMT Splitter,0x00200000,1,1,npsawms.dll,1.00.0008.0708
    KTF MUSIC VoD Audio Effector,0x00200000,1,1,npsvae.dll,1.00.0008.0708
    Moto Image Decoder Filter,0x00600000,0,0,NPSImgFilter.ax,1.00.0000.0001
    Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7140.0000
    StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7600.16385
    AVI Mux,0x00200000,1,0,qcap.dll,6.06.7600.16385
    Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7600.16490
    File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7600.16490
    File Source (URL),0x00400000,0,1,quartz.dll,6.06.7600.16490
    Media Center Extender Encryption Filter,0x00200000,2,2,Mcx2Filter.dll,6.01.7600.16385
    AudioRecorder WAV Dest,0x00200000,0,0,WavDest.dll,
    AudioRecorder Wave Form,0x00200000,0,0,WavDest.dll,
    SoundRecorder Null Renderer,0x00200000,0,0,WavDest.dll,
    Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7600.16385
    Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7600.16385
    BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7600.16385
    MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.7600.16490
    WDM Streaming Tee/Splitter Devices:
    Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,6.01.7600.16385
    Video Compressors:
    WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7600.16385
    WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7600.16385
    MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7600.16385
    DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7600.16385
    MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7600.16490
    Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.06.7600.16385
    DivX 6.8.5 Codec (2 Logical CPUs),0x00200000,1,1,qcap.dll,6.06.7600.16385
    Fraps Video Decompressor,0x00200000,1,1,qcap.dll,6.06.7600.16385
    Intel IYUV codec,0x00200000,
    2010-05-05T14:16:34+00:00
    I have this problem but it's with Adobe & IE8 that action center won't download a solution. It appears the problem is with action center as it says the same thing about checking my internet connection.
