Wireless Network Will Not Connect Automatically On Boot
2010-02-12T14:42:33+00:00
I have Windows 7 Professional.  Every time I boot up I have to to click on wireless icon & enter code key to connect to net.  When I go to Network & Sharing Center, active network is showing.  When I go to Manage Wireless Networks, active network not listed.  When I try to manually add it, I fill in all data and click next, I get notice that access is denied. I have admin. rights. Have talked w/HP & router people to no avail.  Just need to find fix that will automatically connect to internet on boot without necessity of entering key code each time I boot up.  Would greatly appreciate any suggestions.
2010-10-16T12:41:36+00:00
open search, type "services.msc" open services.
Scroll down to "wlan auto config" right click, stop the service.
Navigate to
"C:\ProgramData\Microsoft\Wlansvc\ delete everything in this folder  leaving only a folder called "profiles" delete everything in the "profiles" folder except for a folder called "interfaces" delete everything in the "interfaces" folder)
Restart "wlan auto config" connect to your wireless network, enter
your passkey, (ensure the connect automaticly box is checked)
Restart your computer job done, your computer will now connect to your wireless network automaticly on boot.
2010-10-18T15:15:24+00:00
Hi all, I followed the above advice and thank God you guys got it just right!!! The tip from Fikin to Smokey was right on!! He said to:
I saw this very frustrating issue on both my work and home WLAN. A colleague has helped me to identify the issue and the fix we used is posted below;
  1. Go to the folder C:\ProgramData\Microsoft\Wlansvc\Profiles (it's hidden folder so you'll have to manually type the path from the windows start bar),
  2. Give the local Administrators group full permissions;
 a) In windows explorer, right click within the folder and select properties
 b) Select the Security tab
 c) Click Edit
 d) Select the Administrators group (or if it's not there already, add it)
 e) Ensure all the permissions are ticked, with the exception of special permissions,
 f) Click OK then OK.
  1. Try adding a wireless profile again by going to Network and Sharing Centre - you should not now get the "Access Denied" message.
Hope it helps!
Nikki
This worked Great!!! p.s,  I copied and pasted the folder location instead of typing it out. This fixed it, Thank God. It was just so frustrating. Thanks all, Ben.
91 additional answers
    2011-11-11T10:58:20+00:00
    Excellent!!!!  Works great.  One thing to note though, is that I didn't know why I couldnt find the program data folder, it is because it is hidden.  Thanks to the comment below this one though I got it figured out!  Thank you thank you thank you!!!
    2011-09-21T17:29:13+00:00
    I've tried all the suggested solutions and none have worked. I still have to click on networks and enter code every time.
    HELP!!!!!!!!!!!
    2011-08-31T12:40:58+00:00
    Just had all the issues discussed here and this one worked for me with the additional comments below the double quotes.
    ""open search, type "services.msc" open services.
    Navigate to
    Restart your computer job done, your computer will now connect to your wireless network automaticly on boot.""
    Each folder in the path {C:\ProgramData\Microsoft\Wlansvc\profiles\interfaces} requires the security tab, on the properties sheet, to have all permissions set to everything, not just the end folders. And do not assume the parent directory sets them for all sub folders...check it (at least I had to). In my case I also had to add the correct profile 'Everyone' in my computer due to the NAS box in the mix.
    Hope the additional info to the previous posts helps out.
