Wireless Network Will Not Connect Automatically On Boot
2010-02-12T14:42:33+00:00
I have Windows 7 Professional.  Every time I boot up I have to to click on wireless icon & enter code key to connect to net.  When I go to Network & Sharing Center, active network is showing.  When I go to Manage Wireless Networks, active network not listed.  When I try to manually add it, I fill in all data and click next, I get notice that access is denied. I have admin. rights. Have talked w/HP & router people to no avail.  Just need to find fix that will automatically connect to internet on boot without necessity of entering key code each time I boot up.  Would greatly appreciate any suggestions.
2010-10-16T12:41:36+00:00
open search, type "services.msc" open services.
Scroll down to "wlan auto config" right click, stop the service.
Navigate to
"C:\ProgramData\Microsoft\Wlansvc\ delete everything in this folder  leaving only a folder called "profiles" delete everything in the "profiles" folder except for a folder called "interfaces" delete everything in the "interfaces" folder)
Restart "wlan auto config" connect to your wireless network, enter
your passkey, (ensure the connect automaticly box is checked)
Restart your computer job done, your computer will now connect to your wireless network automaticly on boot.
2010-10-18T15:15:24+00:00
Hi all, I followed the above advice and thank God you guys got it just right!!! The tip from Fikin to Smokey was right on!! He said to:
I saw this very frustrating issue on both my work and home WLAN. A colleague has helped me to identify the issue and the fix we used is posted below;
  1. Go to the folder C:\ProgramData\Microsoft\Wlansvc\Profiles (it's hidden folder so you'll have to manually type the path from the windows start bar),
  2. Give the local Administrators group full permissions;
 a) In windows explorer, right click within the folder and select properties
 b) Select the Security tab
 c) Click Edit
 d) Select the Administrators group (or if it's not there already, add it)
 e) Ensure all the permissions are ticked, with the exception of special permissions,
 f) Click OK then OK.
  1. Try adding a wireless profile again by going to Network and Sharing Centre - you should not now get the "Access Denied" message.
Hope it helps!
Nikki
This worked Great!!! p.s,  I copied and pasted the folder location instead of typing it out. This fixed it, Thank God. It was just so frustrating. Thanks all, Ben.
91 additional answers
    2011-03-20T12:26:45+00:00
    Access denied is related to the Windows folder and file permissions, not the network. It means Windows cannot write anything to that specific folder with the current user. Grant your user full privileges and it should work. I got working that way, anyway.
    Follow hvactech123's advice for that. And make sure you have disabled User Access Control (UAC), it only makes things more complicated.
    2011-01-19T20:52:07+00:00
    Hi there,
    With a brandnew laptop I had a simular problem. At every reboot or when waking up out of sleep mode the wireless was disabled. First I solved this by putting 'MS Mobility Centre' in the startupfolder (in startmenu) after a reboot I clicked to enable the wireless. This was an anoying clickexperience after every reboot so I found a different solution.
    In the startupfolder I placed a batchfile with only one line of text:
    "@netsh wlan connect ssid=1 interface="Atheros AR9285 Wireless Network Connection"
    Just replace the string between " " with your own adapter description. This description can be found by using the 'ipconfig /all' command on a commandprompt. The output is something like:
    Wireless LAN adapter Wireless Network Connection:
       Connection-specific DNS Suffix  . :
       Description . . . . . . . . . . . : Atheros AR9285 Wireless Network Adapter    <<< This is wat you want to know <<<
       Physical Address. . . . . . . . . : 56-55-68-5E-6B-DD
       DHCP Enabled. . . . . . . . . . . : Yes
       Autoconfiguration Enabled . . . . : Yes
       Link-local IPv6 Address . . . . . : fe81::5515:1410:1c08:1522%12(Preferred)
       IPv4 Address. . . . . . . . . . . : 192.168.100.17(Preferred)
       Subnet Mask . . . . . . . . . . . : 255.255.255.0
       Lease Obtained. . . . . . . . . . : woensdag 19 januari 2011 18:37:47
       Lease Expires . . . . . . . . . . : donderdag 20 januari 2011 18:37:47
       Default Gateway . . . . . . . . . : 192.168.100.1
       DHCP Server . . . . . . . . . . . : 192.168.100.1
       DHCPv6 IAID . . . . . . . . . . . : 239625550
       DHCPv6 Client DUID. . . . . . . . : 2B-48-5D-60-5F-6A-DB-00-01-00-01-14-7E-8D
       DNS Servers . . . . . . . . . . . : 192.168.100.1
       NetBIOS over Tcpip. . . . . . . . : Enabled
    The commandprompt can be opend by typing 'cmd' in the comandline in the startmenu.
    Hope this helps someone!
    GrtZ  Armand0
    2010-11-19T01:33:25+00:00
    Thanks don241, initially didn't work, but ended-up blowing away profiles and interfaces, and now my wireless auto-connects perfectly.
