Low Battery Notification does not pop up when battery reaches critical level after upgrading to windows 7
2009-11-29T22:08:17+00:00
I upgraded to windows 7 recently and the battery notification does not work when the battery reaches it's critical level.  It worked fine with vista.  Before when the battery reached 25% the icon in the notification area there was a visual reminder and when the level reached 5% a pop up would occur.  Now with windows 7 I get nothing to remind me.  I checked in the power options where I can edit my power plans and the battery notification read that it was turned on.
2010-07-24T08:13:18+00:00
I was also having this problem of Windows 7 of just going into hibernate on low battery without notification.
I checked out the Microsoft site for Battery faq and how t change low battery notification which didn't tell me something I didn't already know. So I decided to experiment some. I discovered that when I changed my Critical Battery Action to "Shut Down" from "Hibernate", the Low Battery Notification popped up and  could switch to a power source. I changed the Critical Battery Action back to "Hibernate" and the Low Battery Notification still pops up. I guess the system just needed a little push :)
My install is barely a week old so I guess the installation didn't make the correct settings. Having applied some changes to the settings has caused the system to behave correctly in this case.
I hope this will help others with this issue.
Cheers
2009-11-30T19:50:34+00:00
Hi ejslate82,
Welcome to Microsoft Answers.
****I would suggest you to follow the below mentioned steps and check if this helps -
The icon might be hidden. Here's how to show the battery icon:
  1. Right-click an empty area on the taskbar, and then click Properties.
  2. Under Notification area, click Customize.
  3. In Notification Area Icons, click Turn system icons on or off.
  4. On the Turn system icons on or off page, under Behaviors, click On in the drop-down list next to Power, and then click OK.
Refer to the below mentioned links for additional guidance on the issue –
Battery meter FAQ –
http://windows.microsoft.com/en-US/windows7/Battery-meter-frequently-asked-questions
How do I change low battery notification -
http://windows.microsoft.com/en-US/windows7/How-do-I-change-the-low-battery-notification
Hope this helps. Let us know the results.
Meghmala – Microsoft Support
66 additional answers
    2015-08-16T04:42:06+00:00
    i checked everything you posted but still laptop does not pop a notification when battery is low directly switches off. Please help !!
    2014-11-12T20:31:06+00:00
    1. :))))))))))).. I don't care.. It always works 4 me..:))))))))))
    2. :|||||||||||||||||||||||... Zabiya.. I guess my language sounds familiar 2 u, mr lovely! doesn't it?
    bashoooo000m faghatttttttttt mr lovely :DDDDDDDDDDDD
    2014-11-09T15:39:46+00:00
    Well, i have no idea if u'd read this someday, BUTTTTTTTTT I MUST SAY Bashoo00ooom 2 u.... -it just means tnxxxxxxxxxx in my language-..
    i found this way soooooooo Bah Bah-means helpfullllll and kind of realllly brilliant -
    .. i usually do such things 2 these technological stuff..
     Bashooo00oom Cheeeeeeeeeers vbennyda
    Hi Modire,
    1. It's not always "Bah Bah" to do such things 2 ur "technological stuff". U might get them screwed up!
    2. your language sounds fascinating to me. would u plz tell me what language u speak and which country u live in?
    Bashoo00ooom very much.
