fix problem "local only" when connection is across a wireless connection
2008-12-29T21:58:54+00:00
access point appear: unidentified network
internet appear bloqued
access: Local only
connection: wireless connection.
Please help check what is the reason "local only".
ip is assigned automatically by DHCP, but is not possible to connect to internet, the problem appear only on windows vista Pcs, in my other computer with XP version the connection is good.
I have Microsoft Windows Vista Home Premium SP1.
69 additional answers
    2010-02-17T13:20:36+00:00
    So what type of antivirus software do you have that will not cause this problem??  I have been dealing with this local access only for a few years, and yes, I have Norton installed!  If that is indeed the answer, I will purchase new antivirus software TODAY!!!  :-)    Oh this is good........I am sitting here waiting to be reconnected to the internet!  Lost my connection in the short time it took to type this reply!!!
    2010-02-15T20:35:21+00:00
    Norton Remover Tool worked for me also.  I tried everything listed on all the other forums before finding this forum.
    Download Norton Tool Put it n a Flash Drive fix problem and Surf On!!!!!
    2010-02-11T02:38:13+00:00
    Folks I tried everything here and when I got to the Remove Norton Tool mentioned above, that immediately  fixed my "Access: Local Only" problem.  That was the answer for me...  Thanks to all contributors.
  4. Deleted
