fix problem "local only" when connection is across a wireless connection
2008-12-29T21:58:54+00:00
access point appear: unidentified network
internet appear bloqued
access: Local only
connection: wireless connection.
Please help check what is the reason "local only".
ip is assigned automatically by DHCP, but is not possible to connect to internet, the problem appear only on windows vista Pcs, in my other computer with XP version the connection is good.
I have Microsoft Windows Vista Home Premium SP1.
69 additional answers
    2011-08-17T15:10:45+00:00
    uninstalling the driver, rescanning hardware and allowing Vista to reinstall the driver.  solved the problem for me.
    2011-08-10T02:11:35+00:00
    I have the same problem.
    Same machine Dell Inspiron 1525, same wireless card 1395, same message LOCAL ONLY.
    I run this FIx called MicrosoftFixit50357 downloaded from this post ->
    http://support.microsoft.com/default.aspx/kb/928233
    just click and restart the laptop and it worked.
    I hope you enjoy the solution!
    Tuve el mismo problema.
    Con la misma maquina y caracteristicas  Dell Inspiron 1525, same wireless card 1395, same message LOCAL ONLY.
    Descargue el FIx llamado MicrosoftFixit50357 descargado desde este post->
    Solo le di clic y reinicie la laptop y FUNCIONO
    Espero disfruten la solucion.
    ******@hotmail.com
    2011-07-30T10:54:02+00:00
    It is helpful
    Thank you very much buddy
    "I followed the article and solved the problem....."
    2011-07-21T21:16:37+00:00
    idont have wificonnection how i can install
