Windows 7 wireless connection problem - No Wireless Connections Available
2009-10-29T01:02:56+00:00
I have just changed from Vista Home to Windows 7 Professional on my laptop. The laptop will access the internet with a wired connection only. It now indicates there are no wireless networks to join even though my is one of 50 in the area. I asked Windows to diagnose the problem but it has no suggestions.
Thank you.
2012-04-11T02:51:01+00:00
Thanks for the help!
I am now able to "see" the wireless connections but not connect when I click to access the connection.
Friends who visit with their PC's can access my home wireless after they login with the password if they are using Windows XP and/or Vista.
My Windows 7 is still an enigma!
Spent $99 and 1/2 day with Microsoft online tech support without a solution!!!!
Upgrade to Windows 7 has been a "bummer" --- may have to go back to XP or Vista if Microsoft does not provide an update fix.
Again, thanks for the assist!
SOLVED Just signed up to perhaps help the miriad of stressed people as I was. I had 5 computers connected to home network combination of Vista and XP - no network problems. Bought new laptop with Win 7. Connected fine to network.
Left laptop alone for week or so - didn't even turn it off and when I tried to start it up - no network connection possible! Could still "see" network but wireless just would continually try to connect without success. Attached a ethernet cable from router to laptop and it connects fine - just no wireless.
Messed around with aes, tkip, antivirus plus heaps of other suggestions. But the solution was to upgrade the firmware on my router. Downloaded it from tplink website and opened the routers setting webpage and uploaded the newest firmware.
There's no doubt it is a Win7 problem as the old firmware works fine with xp, vista but they don't tell you this when selling you win7 and you spend heaps of time trying to find these solutions. I didn't try system restore but this would've been my next step as the win7 did work for a couple of weeks before it went down, so it has to be some kind of update or something that conflicted with the router after previously working.
Hope this helps someone.
2012-06-17T22:23:48+00:00
While what you have listed here are some good basic things to follow, I was already doing them.  I saw my problem show up when a patch was applied to my laptop.  Originally I saw that patch being offered by the ASUS laptop update utility.  I backed it out and the problem went away.  Later I installed some Microsoft patches and the problem came back.  Here is the issue I am seeing:
When I first bring up the system the WIFI is never turned on automatically, as it is supposed to be and as it used to do prior to the patch.  I have to select the icon in the system tray, which shows the WIFI as of to turn it on.  It does so for all for about 5 seconds, just long enough to attach to the network, and then it turns itself off again!  I then have to do this a second time and that one will work.
It also turns itself off when any device changes are made to the system, such as plugging in or removing a USB flash drive.
I sometimes see it turn itself off when my screensaver has been running for a while, but it has to have been for quite a while, say at least 20 minutes.
I have completely disabled it being powered off by Windows, so it shouldn't ever be turning this off unless I tell it to.
This system has Intel My WiFi Technology in it and I saw some post about updating Intel drivers from their site fixed a similar issue, but it turns out that was for a different Intel WIFI chipset than what I have.  I have verified I am on the latest version of their drivers.
This become quite intolerable when I am at class at ITT and need to be on the network using my WIFI connection.
I am open to any suggestions.  Right now it seems my only option is to backout the last set of patches from Microsoft, because I don't know just which one causes the problem, and ignore all other patches that are made available.  That is not a good solution, because it means I will be ignoring possible security and bug fixes that I actually do need.
Mike
Hello Everyone,
I wanted to thank you all for the active discussion in this thread, and I would like to jump in and see if I can help address the multiple issues that seem to be covered in here.   I would also like to take the opportunity to thank Barb Bowman (MVP) for their efforts in this thread to date 
For a full list of steps to try, see the Wired and Wireless Tutorial on this page:
http://windows.microsoft.com/en-US/windows/help/wired-and-wireless-network-connection-problems-in-windows
After reading through the thread, there appears to be some confusion regarding Wireless Networking technologies and configurations using Windows 7 and I would like to spend some time to try and clear things up with some basic troubleshooting / best practices for Wireless Network related issues.
1.       First try and power off your modem, router and desktop/laptop. Then power on the modem, then the router, and then finally the desktop/laptop. Please do this in that order, allowing 60 seconds in between each device to enable the device to be fully booted and able to accept connections.
2.       Update the drivers for your wireless network adapter via Windows Update, or by using the website for either the company you bought your PC/Laptop from or the manufacturer of your networking device.
3.       Ensure that your router is set to broadcast it’s network name (SSID), ensure that you are connecting to the correct wireless network (SSID) and that you are using the correct WEP/WPA  passkey on both devices.
a.       Please use “Windows Connect Now” or “Wi-Fi Protected Setup” if available on your wireless router to ensure that the connection is setup correctly.
4.       If you are trying to use WPA or WPA2, please ensure that both your network adapter and wireless router support this protocol. If you are having issues detecting your wireless network when using WPA or WPA2, try configuring your router to use WEP instead and see if you can connect.
a.       Please note that the change between WEP/WPA/WPA2 will need to be made on both your computer and wireless router.
b.      If you are only able to connect using WEP, then your networking hardware may need a firmware upgrade. If you are not comfortable doing this yourself, please call your hardware/router manufacturer for help in doing this.
5.       If you are having a problem with your wireless connection after resuming from hibernate or sleep, or are having intermittent connectivity issues, try to adjust your Power Management profile to change your Wireless Adapter Settings to Maximum Performance.
a.       To do this click “Change Plan Settings” next to your Power Profile, and choose “Wireless Adapter Settings” and set it to Maximum Performance. You should do this with all of your power profiles. Additional guidance is available here: http://windows.microsoft.com/en-us/windows7/products/features/power-management
6.       Call the support line for your router manufacturer. It is likely that neither Windows nor the router are having problems, it is simply an issue of getting the configuration settings on both set up to work correctly together. The router manufacturer will be the best resource to know how to configure their device.  Most of the contact numbers are listed here: http://support.microsoft.com/gp/vendors/en-us
For more information please see the following links:
http://windows.microsoft.com/en-us/windows7/Why-can-t-I-connect-to-a-network
http://windows.microsoft.com/en-us/windows7/set-up-a-wireless-router
http://windows.microsoft.com/en-us/windows7/Add-a-device-or-computer-to-a-network
http://windows.microsoft.com/en-us/windows7/Wireless-networking-frequently-asked-questions
I will continue to monitor this thread but will likely end up splitting this thread into individual smaller threads to address the various different issues that have been mentioned so far.
If anyone has any questions please let me know.
Kevin
If you find that my answer was what you were looking for, please remember to click the "mark as answer" box below!
2010-04-24T00:42:02+00:00
Hello Everyone,
http://windows.microsoft.com/en-US/windows/help/wired-and-wireless-network-connection-problems-in-windows After reading through the thread, there appears to be some confusion regarding Wireless Networking technologies and configurations using Windows 7 and I would like to spend some time to try and clear things up with some basic troubleshooting / best practices for Wireless Network related issues.
Kevin
507 additional answers
    2010-12-29T11:07:46+00:00
    A typical Microsoft response - only in Title does it find common grounds with the actual issue; copy/paste of junk info anyone? Sick and tired of it, that's why I quit working for MS, as NO ONE cares!
    You didn't even 'listen' to the question. He says he can NOT SEE any networks that usually are showed as they are in the area.
    What you've done, and a few others is followed general procedures that only deal with, as I said, Title of the problem - as in, no wireless connection - way too general.
    I'm having the same issue, and that is due to Win7 not having drivers and not being able to find any  - not to blame windows, as sometimes distributers don't provide updated drivers - u might need to use VISTA ones, or even try XP ones, as I am right now, make sure to go to driver's .exe and set proper compatibility mode if that's the case.
    You might just have to go to mfg's website, once you find out the name of your wireless controller/adapter. I recomend using SIW (System Information for Windows) to learn about your hardware - its free software - Bingle it.
    Then you need to proceed to mfg's website - could be components' mfg such as Intel for their wireless adapter drivers, or it could be Dell for eg. they all have driver database and will at least have non-Win7 solutions.
    As this Q has been posted 7 lightyears ago, my post won't matter, I just feel like saying something because I'm pulling my hairs out as I just encountered the same issue. Cheers!
    2010-12-28T03:23:16+00:00
    hi kevin. i've been reading through the thread but its quite long and i cant really see many people who have had much success. im trying to set up a wifi for my folks and the router works fine and and i can use it fine on my iphone. the problem is the laptop, it picks up the router but when i try to connect it tells me "windows was unable to connect to XXXX" troubleshooting does nothing apart from tell me to restart my router or modem which in turn does nothing. ive updated firmware for the router and drivers for the network adaptor and just about everything else i can think of.
    im using a belkin n wireless router
    an acer aspire laptop with a broadcom network adapter running windows 7
    could you let me know if you have a solution please, thanks
    Most Recent Solution Update 12/27/10 Like many of you, I was frustrated in the past 2 days trying to figure out why suddenly I lost wireless connection on my 2 computers. I came to this forum to seek answers and do everything possible that was suggested by you, rolling back the driver, updating the software, updating the drivers; someone even suggested the power settings, and so on. What many don’t know is that Microsoft released security updates that screws everyone wifi connections. Unfortunately for us having automatic updates this disabled our wireless. To protect their windows7 security reputation Geniuses have disabled our connection to the internet. When I disabled password for my router( mine is Linksys WRT 160N) security connection from WPA2-PSK to unsecured, wifi connection was established( maybe that’s why so many of my neighbors have recently unsecured connections). So the only problem was why suddenly IPv4 Connectivity was unable automatically connect with wireless using WPA, or WPA2-PSK, AES? Since unsecured connection worked fine for my router or unsecured connection for my neighbor’s routers, I decided to re-install the router. If you are trying to go to Device Manager, you may as well save your time, for all you going to see there under Network adapters is *This device is working properly* and so it does. Rolling back or updating your driver will likely do nothing for you. Let me make this clear: Your router is working properly, your wifi card is working properly, your modem is working properly, do not look for solutions to the problem in there. But let me tell you what happened next. So I reinstalled my Linksys router from scratch and everything went smooth, I even downloaded latest software version from their website over my wired Ethernet. I was almost done with the installation when my wifi failed again to connect- it tried for 30 minutes. So I gave up and look for the number to tech support as a last resort. There I was informed I had to pay $29.95 for one time service since my warranty just ended recently (its free for those on warranty). I really don’t like to pay for something I am sure I can fix myself. But I had to give a try, and paid. This was a really great experience to talk with someone with broken English and hardly heard him too, but he was polite. Of course he suggested everything I already done myself-I am thinking to myself-great what a waste of money. And then he asked me if I have the latest firmware version, I responded that I just downloaded latest software with drivers. Then, I went to Cisco website to get their newest firmware version –downloaded to my desktop, then manually went to http://192.168.1.1 to Cisco website (you will be prompt for password to you router) to get to that website (remember different routers may have different web address) find yours from your wireless broadband router manufacturer. In that site I changed to channel 9, width 20MHz, network mode to mixed, and configuration to manual. In here, I went to Administration tab-Firmware Upgrade tab, then I uploaded recently downloaded new firmware version from my desktop. Wireless is working flawlessly now. Conclusion The key is to download a new firmware version for your wireless broadband router. Recent Microsoft security update has disabled automatic- secured connections to our wireless router. Microsoft forced manufacturer to update their routers firmware versions to be able to work with Windows7 OS, of course we did not know about it. P.S. Most of you will be able to configure this on your own. However, for those who want a tech support remember its free if you on warranty. It does not matter what router you have, all been affected by security update that requires you to download latest firmware version. Hope this help you all. Cheers from Alaska.
