Automatic volume leveling during audio playback
2009-11-05T13:16:13+00:00
This is really annoying:
Quiet sound is amplified to sound at a reasonable level. Then when a loud part of the song comes on the level automatically drops making the quiet parts sound annoyingly loud & the loud part annoyingly quiet... Sorry that's the best way I can describe this... again:
Only happens when its had a few seconds on silent (eg. pause) - at that point the system starts to "think" for itself creeping the base volumes up. Then when the song begins again you are treated to loudness that is quickly quietened when the system realises there is a higher level of sound coming through...
This is very frustrating because I use my computer to record & as such need to have the audio playing at its proper level - not the level the computer thinks it should be playing at...
I have combed through the settings looking for an "auto off" option, and have spent a long time searching for an answer online.
Any help you could offer would be greatly appreciated.
Thanks!
2009-11-05T22:23:05+00:00
Hi pablo647,
We would like to get a little more information from you to help troubleshoot your issue.
Are you using any Sound Card on the machine?
You can try playing the same song to a differnet Headphone or the Speakers.
I suspect it could be a problem with the sound card drivers.
You can update the drivers for the sound devices and try after that.
  1. Click Start and then click Control Panel.
  2. Click System and Maintenance, click System, and then click Device Manager.
Note If Control Panel is in Classic View, double-click System, and then click Device Manager.
  1. If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
  2. In Device Manager, expland "Sound Video and Game controllers", right-click the "Sound Video and Game controllers" and go to properties.
  3. Browse to the Update tab and then click on update driver.
You may also check on the Sound card manufacturers web site and verify if they have any updated drivers for Windows 7 and try to install it.
Hope it helps.
Thanks and Regards:
Shekhar S - Microsoft Support.
Visit our Microsoft Answers Feedback Forum
109 additional answers
    2010-02-22T09:13:51+00:00
    Hi Guys,
    This is going to make me sound terribly inexperienced, however I found that the answer to my conundrum was the actual amplifier the sound was running through post DA conversion.
    ie. it was not Windows causing the volume fluctuations, it was my amplifier - more specifically, my pre-amp.
    Through my tedious study of the Windows 7 operating system as a professional recording platform, I have come to a decisive conclusion: XP SP3 is a much more "tweak-able" platform.
    I have rolled back to XP now & I'm happy as!
    Dont get me wrong, it was difficult leaving the auto size windows & those glorious desktop widgets, but it XP for me!
    Sorry to have started this issue then bolted!
    2010-03-03T03:36:05+00:00
    We have a customers laptop in at the moment with a similar problem. However he is having a problem with the microphone volume going lower all the time.....
    Anyone else having this issue as well?
    Laptop is Toshiba Satellite
    lUKE
    2010-03-20T08:07:11+00:00
    I'm not sure if someone gave this answer already, but I think it's because Windows 7 automatically turns down other sounds when a second one plays. I noticed this when I was trying to play games without the background music and play music on my music player (any) with it. What happens is that the music just dies down, leaving the second loaded sound louder.
    What I did was:
    1. Go to the sound icon on the system tray, right-click, and click Sounds;
    2. Click on the Communications tab. On this one, you will see:
    Windows can automatically adjust the volume of different sounds when you are using your PC to place or receive telephone calls.
    When Windows detects communications activity:
    o Mute all other sounds o Reduce the volume of other sounds by 80%
    o Reduce the volume of other sounds by 50%
    o Do nothing
    1. Select "Do Nothing", then try and check if it works. Mine worked seamlessly since this. :) I hope it helps!
    -reine
    2010-04-01T16:38:18+00:00
    I purchased a brand new Toshiba Satellite laptop last week that does the same thing. I stumbled across this thread while searching the web for a solution. From what I gather, this is a Windows 7 issue and not a problem with my laptop. I never had this problem while using Vista on my previous laptop. BTW... I'm using Winamp for my music player.
