Automatic volume leveling during audio playback
2009-11-05T13:16:13+00:00
This is really annoying:
Quiet sound is amplified to sound at a reasonable level. Then when a loud part of the song comes on the level automatically drops making the quiet parts sound annoyingly loud & the loud part annoyingly quiet... Sorry that's the best way I can describe this... again:
Only happens when its had a few seconds on silent (eg. pause) - at that point the system starts to "think" for itself creeping the base volumes up. Then when the song begins again you are treated to loudness that is quickly quietened when the system realises there is a higher level of sound coming through...
This is very frustrating because I use my computer to record & as such need to have the audio playing at its proper level - not the level the computer thinks it should be playing at...
I have combed through the settings looking for an "auto off" option, and have spent a long time searching for an answer online.
Any help you could offer would be greatly appreciated.
Thanks!
2009-11-05T22:23:05+00:00
Hi pablo647,
We would like to get a little more information from you to help troubleshoot your issue.
Are you using any Sound Card on the machine?
You can try playing the same song to a differnet Headphone or the Speakers.
I suspect it could be a problem with the sound card drivers.
You can update the drivers for the sound devices and try after that.
  1. Click Start and then click Control Panel.
  2. Click System and Maintenance, click System, and then click Device Manager.
Note If Control Panel is in Classic View, double-click System, and then click Device Manager.
  1. If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
  2. In Device Manager, expland "Sound Video and Game controllers", right-click the "Sound Video and Game controllers" and go to properties.
  3. Browse to the Update tab and then click on update driver.
You may also check on the Sound card manufacturers web site and verify if they have any updated drivers for Windows 7 and try to install it.
Hope it helps.
Thanks and Regards:
Shekhar S - Microsoft Support.
Visit our Microsoft Answers Feedback Forum
109 additional answers
    2011-04-21T17:21:55+00:00
    You know exactly whats wrong with this. Microsoft decided in their most brilliant move yet to remove even more functionality from windows by adding an auto volume leveling mixer. What is the point of this? I am quite capable of turning down my volume, if it is too loud, thank you. I am sick and tired of trying to use my computer and windows stops me at every turn by making sure I don't do something I shouldn't. I know what I'm doing thank you. I don't need to be asked if I'm sure, I don't need windows to do it for me, because some moron 13 year old deleted their system32 folder. **** OFF WITH THIS BULLSHIT. Windows 7 was not my idea, it was the idea of some barely functional retard. The ONLY reason I use this piece of **** operating system is because I like to play games and seeing as you monopolise every area of the gaming OS market, I'm not left with a choice.
    2011-05-19T23:21:14+00:00
    ok, what fixed this for me is to navigate to your sounds properties. Right click the speaker in taskbar, click on playback devices. Sselect your sound output and properties, goto the advanced tab and uncheck - Allow applications to take exclusive control of this device. Since i have unchecked this my problem of volume flexing has gone away..
    2011-07-03T05:19:13+00:00
    Jerry,
    It is odd for me that you are having this problem elsewhere as mine seems to have subsided. Regardless, so far I have one possible solution with reference to one of my previous emails in this forum (so forgive me if you've already tried this). I came across something in the control panel when I was having this problem with the sound, I came across something called 'loundess equalisation' that supposedly 'uses understanding of human hearing to reduce percieved volume differences'. Go into the Control Panel, click 'Hardware and Sound' then click 'Sound'. In the Playback tab there should be an Icon for 'Speakers' right-click this and choose properties. Once the Speakers window has opened, select the 'enhancements' tab and look for 'loundess equalisation' in the toggle/selection box.
    This is all I have for now.
    Matt
    Matt, you are a lifesaver.
    2011-08-02T00:02:40+00:00
    *I HAVE A SOLUTION FOR USES WITH REALTEK HD AUDIO ONBOARD SOUND CARDS*:
    1. Right click the Volume icon in the bottom right
    2. Click Sounds
    3. Go to the Playback tab
    4. Right click Speakers (or your currently working check-marked audio device)
    5. Click properties
    6. Go to the Enhancements tab
    7. Check the box labeled "Disable all sound effects" and prepare for a boost in volume if you are currently listening to music. Music will not automatically level down anymore!
