I disabled my default microphone, how do I enable it again.
2010-05-09T13:44:01+00:00
I recently got a laptop with windows 7. I bought a Microsoft web-cam and when I was playing with Audacity, I realized that the mic in the web-cam was better than the built-in mic my laptop had. So I went to control panel/sound and I disabled the built-in microphone and left only the web-cam microphone enabled. When I went back to Audacity it showed a message that said "Error while opening sound device. Please check the input device settings and the project sample rate". Did i do something wrong? How do I make my built-in mic go back to normal?
Thank you,
Laura
2010-05-10T12:51:43+00:00
Hi Laura,
As you have disabled the built-in Microphone, first lets try to set the Microphone as a Default Device and enable the same.
Perform the task mentioned below to set Microphone as default device and then enable it.
  1. Go to Start and click on control Panel.
  2. Click in Sound, then a new window will open up.
  3. In the new windows click on the tab "Recording” and right click in the window and click on Show Disabled devices.
  4. Now check if the microphone is listed there and highlight the microphone and click on "Set as Default" device.
  5. Now right click on it and choose enable.
Doing this will enable the built-in Microphone.
Check if the issue persists  now.
Refer this link for additional information:
Tips for fixing common sound problems
http://windows.microsoft.com/en-US/windows7/Tips-for-fixing-common-sound-problems
Regards,
Divya R – Microsoft Support.
54 additional answers
    2012-04-15T08:11:40+00:00
    I had the same problem. This fixed it, thank you. But poorly designed IMO
    2012-06-13T18:55:31+00:00
    Hi Divya,
    I had the same issue wtih microphone and thank you for your nice steps of solution.
    Your help is very much appreciated.
    Kind Regards,
    Laxman
    2012-06-18T06:05:07+00:00
    Control panel, sound, recording, right click in the middle of the window, select "show inactive devices" click on your "built in mike". Viola
    2012-08-25T11:11:08+00:00
    The solution to this particular problem is very simple at the end, but MS made it so hard for people to find it. Now we can understand why MS is playing catch-up in a number of areas because they put so much resources in telling people how to solve such an easy problem instead of thinking about designing better products. Why can they just put a button in the window, saying something like show disabled devices??!!
