I disabled my default microphone, how do I enable it again.
2010-05-09T13:44:01+00:00
I recently got a laptop with windows 7. I bought a Microsoft web-cam and when I was playing with Audacity, I realized that the mic in the web-cam was better than the built-in mic my laptop had. So I went to control panel/sound and I disabled the built-in microphone and left only the web-cam microphone enabled. When I went back to Audacity it showed a message that said "Error while opening sound device. Please check the input device settings and the project sample rate". Did i do something wrong? How do I make my built-in mic go back to normal?
Thank you,
Laura
2010-05-10T12:51:43+00:00
Hi Laura,
As you have disabled the built-in Microphone, first lets try to set the Microphone as a Default Device and enable the same.
Perform the task mentioned below to set Microphone as default device and then enable it.
  1. Go to Start and click on control Panel.
  2. Click in Sound, then a new window will open up.
  3. In the new windows click on the tab "Recording” and right click in the window and click on Show Disabled devices.
  4. Now check if the microphone is listed there and highlight the microphone and click on "Set as Default" device.
  5. Now right click on it and choose enable.
Doing this will enable the built-in Microphone.
Check if the issue persists  now.
Refer this link for additional information:
Tips for fixing common sound problems
http://windows.microsoft.com/en-US/windows7/Tips-for-fixing-common-sound-problems
Regards,
Divya R – Microsoft Support.
54 additional answers
    2017-01-02T13:32:21+00:00
    My issue: Recordings tab hasn´t installed any devices yet. Where can I install it?
             I did all steps.
                                                      help.
    2017-01-02T15:31:08+00:00
             I did all steps.
                                                      help.
    Get a Mac
    2017-05-12T07:25:10+00:00
    fake ..one
    2017-05-12T20:58:37+00:00
    Hi, Laura and Divya R.
    I am using Windows 10 but remember that use of the icons in the Task Bar (by right-clicking them) launches their properties which allows the user to change these. Thus, one can enable/disable them immediately from the desktop in Windows 7+. I hope this is still true for that OS as well as the most current one I use. Good luck.
    BearlyAlive
