Audio playback through headphones and speakers
2009-10-25T00:30:33+00:00
Headphones or speakers in windows 7, Can't have both?
Looked over the other questions, nothing seemed close.
My machine was dual boot, XP and Vista ultimate, now XP and Windows 7. In both XP and Vista I could have the speakers and the headphones plugged in together, both playerd noise, and I could use one or the other by plugging them into the front and back audio jacks.
This enables me to play games during day with speakers, and then at night with head phones, and no reaching round under my desk to remove cables.
Now I am using windows 7 and amongst the many other problems I have with it, I can't play with speakers or headphone until I have gone through a silly lot of clicking to disable one or choose the other as default. Why has this been changed in windows 7 after Vista, it seems an utterly pointless logic. I can turn my speakers off with the power button and get the headphones working. Now I am either or. So my brand new IR head phones are wasted. Please someone tell me there is a work around?
It's little meddling silliness like this that make me want to remain in XP.
Much thanks in anticipation someone has figured a work around.
2010-05-18T17:05:27+00:00
I've got both my Jabra GN9350 and my laptop speakers playing audio at the same time. :)
Here's the trick (and it's been verified on 3 other Win 7 systems):
  1. R click on your speaker icon, select 'Recording Devices' (if you have the sounds dialog up, it's the 2nd tab 'Recording')
  2. R click in the white space, be sure that BOTH "show disabled devices" AND "show disconnected devices" are checked.
  3. **Now this step is going to take a little bit of thought for each computer being used: on my laptop (HP Elitebook) I get a device "Stereo Mix", ENABLE this device.
  4. Click on Properties, go to the tab 'Listen'
  5. Check the box "Listen to this device", also change the drop-down box below "Playback through this device" to be your second audio device
-- To verify that you've done this correctly, go back to the Sound dialog tab Playback, you should now see both of your audio devices showing the little green graphs moving.
Here are the specific settings that I have on my laptop, maybe this will help with your settings:
Speakers- GN9350 (Default Communications Device)
Speakers- SoundMAX Integrated Digital HD Audio (Default Device)
Stereo Mix- 'Listen' feature points this  device to my GN9350 headset.
Paul
2009-12-02T19:11:46+00:00
Right. Your hardware has not found a driver that works in Win 7. You will have to keep checking for updates for that to use the device in Win 7 the way you want it.
Rating posts helps other usersMark L. Ferguson MS-MVP
64 additional answers
    2012-02-13T04:13:18+00:00
    This is not correct for Windows 7 64-Bit SP1
    You cannot uncheck a device as the default.  You can only go to a device that is not selected as default and make it default.  Once you do, the headphones stop playing, or speakers, etc.
    This is a royal pain in the butt and a bad assumption that people would not want both speakers and headphones playing the outpout mix at the same time.  This is important for simplicity in a large number of situaltion simply to have the headphones and speakers on.
    I've searched and searched and found no real answer to having both speakers and headphones playing at the same time.  Can someone willing to actually test the situation from Microisoft please answer?
    That "hardware driver" thing is a bunch of bologna.  The drivers are working brilliantly.  This is a failure of the OS to simply double direct the sound output to more than one device.
    2012-05-29T04:09:53+00:00
    You are a legend! Thanks! :D
    2012-06-17T14:56:06+00:00
    Just had to login and thank the poster for this - sorted my headphones/speakers in 30 seconds. Still works on the latest version of Windows 7.
