Audio playback through headphones and speakers
2009-10-25T00:30:33+00:00
Headphones or speakers in windows 7, Can't have both?
Looked over the other questions, nothing seemed close.
My machine was dual boot, XP and Vista ultimate, now XP and Windows 7. In both XP and Vista I could have the speakers and the headphones plugged in together, both playerd noise, and I could use one or the other by plugging them into the front and back audio jacks.
This enables me to play games during day with speakers, and then at night with head phones, and no reaching round under my desk to remove cables.
Now I am using windows 7 and amongst the many other problems I have with it, I can't play with speakers or headphone until I have gone through a silly lot of clicking to disable one or choose the other as default. Why has this been changed in windows 7 after Vista, it seems an utterly pointless logic. I can turn my speakers off with the power button and get the headphones working. Now I am either or. So my brand new IR head phones are wasted. Please someone tell me there is a work around?
It's little meddling silliness like this that make me want to remain in XP.
Much thanks in anticipation someone has figured a work around.
2010-05-18T17:05:27+00:00
I've got both my Jabra GN9350 and my laptop speakers playing audio at the same time. :)
Here's the trick (and it's been verified on 3 other Win 7 systems):
  1. R click on your speaker icon, select 'Recording Devices' (if you have the sounds dialog up, it's the 2nd tab 'Recording')
  2. R click in the white space, be sure that BOTH "show disabled devices" AND "show disconnected devices" are checked.
  3. **Now this step is going to take a little bit of thought for each computer being used: on my laptop (HP Elitebook) I get a device "Stereo Mix", ENABLE this device.
  4. Click on Properties, go to the tab 'Listen'
  5. Check the box "Listen to this device", also change the drop-down box below "Playback through this device" to be your second audio device
-- To verify that you've done this correctly, go back to the Sound dialog tab Playback, you should now see both of your audio devices showing the little green graphs moving.
Here are the specific settings that I have on my laptop, maybe this will help with your settings:
Speakers- GN9350 (Default Communications Device)
Speakers- SoundMAX Integrated Digital HD Audio (Default Device)
Stereo Mix- 'Listen' feature points this  device to my GN9350 headset.
Paul
2009-12-02T19:11:46+00:00
Right. Your hardware has not found a driver that works in Win 7. You will have to keep checking for updates for that to use the device in Win 7 the way you want it.
Rating posts helps other usersMark L. Ferguson MS-MVP
64 additional answers
    2009-10-25T22:11:24+00:00
    Hi alistair M,
    Thank you for visiting Windows Vista Forums.
    Check to see if your headphones are set to be used as the default *Communication* device instead of the default device, or if both devices are set to default. If so, make the headphones default, so that Windows will use them only when they are plugged in.
    Check with  volume settings.
    1. Right click on the speaker icon in taskbar and select volume control options.
    2. put a check mark on "All devices currently playing sound".
    3. Make sure you have "The default communication device unchecked".
    4. place a check mark on both speakers and headphones.
    Let us know what happens when you play.
    Regards,
    Amritha-Microsoft Support.
    2009-10-26T21:06:32+00:00
    Hi Amritha.
    I have done as you asked to no avail. (Though I can now see two volume controls in the options panel.) The system still thinks I have either the headphones OR the speakers to play sound. Not both.
    It also won't detect the headphones being unplugged, so won't alternate between the two formats.
    If I play music through my headphones, with the sound panel from control panel open at the same time. I can see the green bars jumping in time with the music, If I then unplug my headphones, Win7 ignores the headphones have been unplugged, won't jump to speakers to play and so instead plays music to itself. The little green bars just jumping on their own.
    (If that makes sense)
    On a side note while playing with the voumes controls and putting them to full volume in case, I can hear the little beeping noise of the volume controls from the speakers, yet still hear music from the headphones. So the sound is connected and working, it is something software related that is limiting output.
    Hope that helps.
    Thanks again in advance.
    2009-11-25T00:01:30+00:00
    Still nothing, still can't get speaker AND headphones to work.
    In the month since raising this issue. I have had to do a full reinstall of the whole system because Windows 7 isn't very good and crashes.... A lot.
    Now it can't detect the headphones as plugged in at all. So I am either looking at getting a two way head jack or forget headphones completely. Which is hardly making windows 7 seem like a good deal.
    It isn't the physical case. During the second install of windows 7 it corrupted and lost my windows XP dual boot partition. So instead of reinstalling that I used the partition for the shiny new Ubuntu 9.10 and both headphones and speakers work like a dream.
    Now if only I could get call of duty modern warfare to run in ubuntu I could ditch "sin7."
    Not impressed one bit with Windows7.
    Less money on trying to get us to believe windows 7 invented things and more on getting it to work with standard things please.
