XBOX 360 wireless receiver won't connect to controller with Windows 7 64bit
2010-02-23T03:37:19+00:00
Hello, im having a problem with a xbox 360 wireless receiver on my windows 7 64bit, i installed the software that came with the receiver and it installed fine but when i went to connect the controller with the receiver it doesnt work, i've tried it dozens of times and i have rang microsoft for help but they werent too sure. Its a official controller which came with an xbox360 and the receiver isnt microsoft but i was told from the microsoft people that some receivers are made outside of microsoft but are still fine. I'm wondering if there is a specific windows 7 receiver driver for it?
thanks
james
Windows for home | Previous Windows versions | Gaming
2010-03-02T12:27:51+00:00
hey thanks i got it to work! so relieved. heres how you do it:
Right click on Computer
Go to Properties
Click on Device Manager
Right click on the Unidentified Device
Go to Properties
Go to the Drive tab
Click on Update Driver…
Browse my computer for driver software
Let me pick from a list of device drivers on my computer
Microsoft Common Controller for Window Class
Xbox 360 Wireless Receiver for Windows Version: 2.1.0.1349 [8/13/2009]
Update Driver Warning
Click Yes
i cant believe it was that simple, you dont need to download any seperate driver or anything, just follow the steps.
thanks
151 additional answers
    2013-02-01T22:22:53+00:00
    You legend you!
    thank you very much, this has been something troubling me since getting my new 64Bit PC, couldnt properly play halo 2, GTA 4 etc due to my inability of getting on with the Mouse/Keyboard setup
    worked a treat, but obviously since im using a wireless reciever and controller, i had to click the wireless driver not the wired controller you suggested, but thats clear since the list has them all listed
    Again thanks a Bunch!!
    Jonathan
    2013-01-31T07:49:45+00:00
    Thank you so much for this really useful piece of information. Everyone else missed it out.
    2013-01-16T15:30:49+00:00
    Thank you soooo much. I nearly kicked my monitor off my desk!!!
    2013-01-10T07:05:12+00:00
    I have the option of XBOX 360 wireless receiver or xbox 360 controller for windows version2.. the 1 u mentioned. dont no which to install
