Can't find script engine "VBScript" for script.
2010-07-08T20:15:22+00:00
When trying to install Windows Cleanup Utility (msicuu2.exe) this error message appears.  I'm trying to install Java but get the Java Setup error 1723: There is a problem with this windows installer package.  A DLL required for this install to conplete could not be run....
I have Windows Home Premium and it looks like I have the Windows Installer-Unicode Version 5.0.7600.16385
Any steps to fix would be most appreciated.
  1. Ramesh 181.9K Reputation points Volunteer Moderator
    2016-02-22T18:37:47+00:00
    Hi xRoguex,
    See these two replies in the 1st page of this thread for solution.
    Umesh P replied on  July 9, 2010
    and
    auggy replied on  July 12, 2010
    Registering the modules (64-bit and 32-bit) using Regsvr32.exe should recreate the missing registry keys.
    2016-02-22T17:37:45+00:00
    My McCaffey uninstaller was broken so I used Revo to uninstall so now that vbs reg key is completely missing. All the info I find is how to restore the reg key but I cant find anything on what to do if the registry key is completely missing.
    2015-02-19T03:06:55+00:00
    I think it's because even Admins only have read access to some registry entries too. Try the steps on my post earlier. They incorporate things I learnt from the registry access issue in this thread:
    http://superuser.com/questions/601505/why-cant-i-change-window-7-registry-key
    2015-02-19T02:52:16+00:00
    I changed the second file to the right "Data", but then it said, "Cannot Edit: Error writing the value's new contents". PLEASE HELP ME!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    2014-09-23T06:18:10+00:00
    Cheers Noel, but completely removing McAfee isn't an option for me in my work environment, McAfee is a mandatory install.
    So for those lucky enough to un-install McAfee, the MCPR option sounds great.
    But for those people that have to live with McAfee, unfortunately the messy registry tweaks are our only option I know of...
    Unless ofcourse McAfee look into the issue and resolve it, which would be very nice too :) Well, I guess they will eventually, once someone chases them up enough about it.
