Can't find script engine "VBScript" for script.
2010-07-08T20:15:22+00:00
When trying to install Windows Cleanup Utility (msicuu2.exe) this error message appears.  I'm trying to install Java but get the Java Setup error 1723: There is a problem with this windows installer package.  A DLL required for this install to conplete could not be run....
I have Windows Home Premium and it looks like I have the Windows Installer-Unicode Version 5.0.7600.16385
Any steps to fix would be most appreciated.
  1. Deleted
    2011-07-31T03:48:51+00:00
    somehow ,
    after do everything above, it still not work..
    try this...
    your software package maybe contain the "cscript.exe" and as a wrong version vs your Windows
    find out it, rename or remove the cscript.exe from the software package.
    and SYSTEM will execute the currect version automatically.
    that's great^^
    May it help.
    2011-06-06T16:38:47+00:00
    Aha!  My HKEY_CLASSES_ROOT\CLSID{B54F3741-5B07-11cf-A4B0-00AA004A55E8}\InprocServer32 (Default) had a leftover dll from recently-uninstalled   Avast virus scanner.
    As admin, changed HKEY_CLASSES_ROOT\CLSID{B54F3741-5B07-11cf-A4B0-00AA004A55E8}\InprocServer32 permissions to allow updating, then replaced the (Default) value with
    C:\Windows\system32\vbscript.dll
  4. Deleted
    2011-04-27T21:31:46+00:00
    OOOWWWW MYYYY GODDDDDDDDD,
    You´re my hero man, i expend at least 2 days on this problem....the second entry key on mine registry was a reference to mcafee location (sorry my bad english), i add the location of de vb DLL an my problem was solved...tanks alot man...
    From Rio de Janeiro/Brazil
    best Regards
