System claims all fonts are "In Use" when I try to delete them
2010-05-09T17:21:03+00:00
I am attempting to delete some non-system fonts that I installed.  Every time I try, no matter what the font, I am told that the font cannot be deleted because it is "in use".  It does not matter if I close every single program running and double-check that no word processors (I use Open Office) are running through Task Manager, the system will not allow me to delete any fonts.
Please help.
2012-05-07T11:35:25+00:00
Could it be this simple?  It worked for me!
http://forums.techarena.in/vista-help/1189255.htm
The Windows Font folder itself is using the font, hence why you can't delete the font - i.e. the very tool you're using to delete the font is using said font and thus locking the file!
When in the Fonts folder click:
Organize > Layout > Untick 'Details pane' > Now try deleting the font.
Worked a treat for me.
Seriously needs addressing in the next service pack.
2013-10-27T19:11:27+00:00
All,
I MIGHT JUST HAVE THE FIX FOR THIS!!
I've been struggling for 1 hour to delete a font and I've finally done it.
I renamed the font and I could delete it immediately!
Before deleting it I set all the permissions to allow. I don't know if that helped but ultimately it worked.
I was in safe mode and that didn't work until the renaming trick.
Good luck.
G
69 additional answers
    2017-01-04T09:58:35+00:00
    thx for the useful reply, its really works for me
    2016-11-18T04:50:56+00:00
    love too learn that six years and two major versions of windows later you still can't delete fonts in explorer because the preview pane locks the file
  3. Deleted
