System claims all fonts are "In Use" when I try to delete them
2010-05-09T17:21:03+00:00
I am attempting to delete some non-system fonts that I installed.  Every time I try, no matter what the font, I am told that the font cannot be deleted because it is "in use".  It does not matter if I close every single program running and double-check that no word processors (I use Open Office) are running through Task Manager, the system will not allow me to delete any fonts.
Please help.
2012-05-07T11:35:25+00:00
Could it be this simple?  It worked for me!
http://forums.techarena.in/vista-help/1189255.htm
The Windows Font folder itself is using the font, hence why you can't delete the font - i.e. the very tool you're using to delete the font is using said font and thus locking the file!
When in the Fonts folder click:
Organize > Layout > Untick 'Details pane' > Now try deleting the font.
Worked a treat for me.
Seriously needs addressing in the next service pack.
2013-10-27T19:11:27+00:00
All,
I MIGHT JUST HAVE THE FIX FOR THIS!!
I've been struggling for 1 hour to delete a font and I've finally done it.
I renamed the font and I could delete it immediately!
Before deleting it I set all the permissions to allow. I don't know if that helped but ultimately it worked.
I was in safe mode and that didn't work until the renaming trick.
Good luck.
G
69 additional answers
    2016-04-21T12:48:41+00:00
    this DOES NOT actually delete the font, it ONLY removes the registry entry for the font, it STILL appears in Control Panel and in C:\Windows\Fonts and unlocker programs and manual delete STILL say it is in use. The poster before claiming to uncheck 'Details Pane' apparently DID NOT research this far enough, it STILL DOES the "in use" error message with the Details Pane already unchecked.
    This is 2016 and Microsoft STILL has NOT patched this bug???
    2015-11-18T19:21:06+00:00
    I have the REAL answer - none of the others worked for me.
    Depending on your operating system, click in Run/Search, and type regedit.exe and hit enter.
    In the left pane, browse to:
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Fonts
    and delete the unwanted font (mine was a variation of Helvetica) from there.
    Credit to: Jessen P's post, March 7 2013
    2015-11-05T14:33:26+00:00
    I had to unclick the Preview Pane also to get mine to delete. Thanks for the help.
