System claims all fonts are "In Use" when I try to delete them
2010-05-09T17:21:03+00:00
I am attempting to delete some non-system fonts that I installed.  Every time I try, no matter what the font, I am told that the font cannot be deleted because it is "in use".  It does not matter if I close every single program running and double-check that no word processors (I use Open Office) are running through Task Manager, the system will not allow me to delete any fonts.
Please help.
2012-05-07T11:35:25+00:00
Could it be this simple?  It worked for me!
http://forums.techarena.in/vista-help/1189255.htm
The Windows Font folder itself is using the font, hence why you can't delete the font - i.e. the very tool you're using to delete the font is using said font and thus locking the file!
When in the Fonts folder click:
Organize > Layout > Untick 'Details pane' > Now try deleting the font.
Worked a treat for me.
Seriously needs addressing in the next service pack.
2013-10-27T19:11:27+00:00
All,
I MIGHT JUST HAVE THE FIX FOR THIS!!
I've been struggling for 1 hour to delete a font and I've finally done it.
I renamed the font and I could delete it immediately!
Before deleting it I set all the permissions to allow. I don't know if that helped but ultimately it worked.
I was in safe mode and that didn't work until the renaming trick.
Good luck.
G
69 additional answers
    2015-04-23T18:41:22+00:00
    sorry for bumping old post,
    recently i installed font for my blog findyourduck
    then i add otf and ttf to my desktop (win 7 64bit)
    it give me blank page so i decided to delete it, but it doesn't work
    after find something useful i found this : nexus font
    just google it nexus font (after 2 hours without solution) and my problem go away
    2015-03-12T20:22:26+00:00
    In addition to the other helpful suggestions, I found that I also had to "show" the font. Right click on the font name - Show
    2015-01-08T17:21:48+00:00
    AAAAAA!!! IT WORKSSSSSSSSSSS!!!!!
    THANK YOU THANK YOU THANK YOU SOOO MUCH
