Audio stops working but works after a reboot
2009-10-28T13:58:18+00:00
My audio stops working after Windows 7 has been running for a while;
Ideas:
  • the audio will work again after a re-boot but again, it will stop working after Windows has been running for a while. Re-bootig always fixes the problem but only for a few hours and then the audio is gone. audio problem
Remember - This is a public forum so never post private information such as email or phone numbers!
2009-10-29T13:40:44+00:00
Welcome to Microsoft answers forum.
You can check for the sound drivers,whether they are installed correctly.
if not uninstall them and install again.
I suggest you to verify that the default sound device is set correctly
  1. Click Start,type Sound in the Start Search box.
  2. Click Sound in the search results at the top of the Start menu.
  3. Click the Playback tab. Notice the check mark next to the default device. For most users,the default device is Speakers.
Make sure that your audio settings are configured as expected. Follow these steps:
  1. On the Playback tab, select the playback device, click Properties, click the Advanced tab, and make sure that the Default Format is set to the value that you expect.
 When you finish, close this window to return to the previous window.
  1. On the Playback tab, select the playback device, click Configure, and then make sure the configurations are set correctly.
  2. If the sound settings are set correctly, you are using speakers as the sound device, and your speakers are already set as the default device, go to method 5 now.
  3. Select the sound device that you want as the default sound device, and then click Set Default.
  4. Click OK to save your settings and to close the Sound dialog box.
Determine whether you can now hear sound. If you can hear sound, the issue is resolved. If you cannot hear sound, try method 5.
http://support.microsoft.com/kb/948481
you can also check performing clean boot.
To perform a clean boot on a computer that is running Windows Vista, follow these steps:
  1. Click Start,type msconfig in the Start Search box, and then press ENTER.
If you are prompted for an administrator password or for a confirmation, type the password, or click Continue.
  1. On the General tab, click Selective Startup.
  2. Under Selective Startup, click to clear the Load Startup Items check box.
  3. Click the Services tab, click to select the Hide All Microsoft Services check box, and then click Disable All.
  4. Click OK.
When you are prompted, click Restart.
After the computer starts, start the  program and check whether the problem is resolved.
http://support.microsoft.com/kb/929135
Thanks and Regards,
Azam - Microsoft Support
150 additional answers
    2010-03-03T04:01:04+00:00
    Hi I have the same problems, please help me out my computer is a HP dv4, I just buught it so, I want to return it if the problem persists. Please if someone has the solution on how to make my sound work please let me know. Im tired of restarting my computer.
    OS Name Microsoft Windows 7 Home Premium
    Version 6.1.7600 Build 7600
    Other OS Description  Not Available
    OS Manufacturer Microsoft Corporation
    System Name MARCO-PC
    System Manufacturer Hewlett-Packard
    System Model HP Pavilion dv4 Notebook PC
    System Type x64-based PC
    Processor AMD Turion(tm) II Dual-Core Mobile M500, 2200 Mhz, 2 Core(s), 2 Logical Processor(s)
    BIOS Version/Date Hewlett-Packard F.04, 10/26/2009
    SMBIOS Version 2.6
    Windows Directory C:\Windows
    System Directory C:\Windows\system32
    Boot Device \Device\HarddiskVolume1
    Locale United States
    Hardware Abstraction Layer Version = "6.1.7600.16385"
    User Name Marco-PC\Marco
    Time Zone Pacific Standard Time
    Installed Physical Memory (RAM) 4.00 GB
    Total Physical Memory 3.75 GB
    Available Physical Memory 2.08 GB
    Total Virtual Memory 7.49 GB
    Available Virtual Memory 5.16 GB
    Page File Space 3.75 GB
    Page File C:\pagefile.sys
    Thanx
    Marco
  2. Deleted
    2010-03-03T16:00:58+00:00
    Hi Marco,
    Since this is a new HP computer, please contact HP support.
    Chris
    2010-03-04T21:09:41+00:00
    I have the same problem at my office.  We have mostly XP computers, but we have a few Win7 Enterprise Computers.  A couple of them will just lose audio after a random period of time and we will have to reboot.  They have the latest drivers for the audio cards in the laptops, but we are using Logitech USB headsets, so I think that they do not use the onboard audio card?  Would they use some other driver then?  There are no drivers from Logitech for them, so is it some internal Win7 driver that is used for a USB headset?
